Results 1 to 6 of 6
Thread: Dead Reckoning for GPS Software?
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Does any current GPS software support dead reckoning? Most of the installed nav units support this...but nobody seems to have PC Based software that'll do it.
    For those of you who don't know what i'm talking about, dead reckoning bases it's location on the GPS, then, compares GPS to readings from the car to always know where it is, so if the GPS dissapears, the car can continue navigating. Usually this requires a gryo to sense turning (could use an accelerometer), a tap off the car's speed sensor wire, and a tap off the reverse wire (so it knows it's going backwards). My factory GPS had this, and i'm kinda missing it with the amount of overpasses and trees around here.
    I'd specifically be interested in something like this for iGuidance. There's a thread in the Newbie section that has a 2-direction accelerometer that could be used for it..which would be awesome.
    Any ideas? Or am I dreaming too far ahead?
    Super Moderator xBrady's Avatar
    USA
    There isn't any software that I'm aware of. I do know that Scouse Monkey has been working on or has thought of working on the hardware part of it.
    Installed.
    -GPSSecure- - GPS Tracking
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Coon Rapids, MN
    indeed.. I thought it would be ncie to soem hoiw emulate faster GPS intervals..
    to sort of get a psuedo 5hz refresh or something.. but I think this would require some hardware or connection to OBDII .. but with my GPS roof mounted I only loose signal under tunnels and parking garages..
    but if worse comes to worse I have my wife get out the red crayon and a map and draw me a line as we drive ..
    Shawn
    I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
    Check out my web company Minneapolis Web Designer - Himmelberger Design
    May 2005
    Conyers, GA
    It's just annoying that car nav systems have done this for a while, but nobody's porting it to pc! All the computer needs is current speed and rate of turn, and it could figure it out...
    Jun 2004
    AZ
    I second this idea.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Jahntassa
    Or you can find an OEM GPS module with dead reckoning build in for $200.
  1. Looking for Non ELM software for OBD II
    By Refael Azi in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-19-2006, 11:32 AM
  2. Garmin nRoute Software for Laptop
    By rgardjr in forum GPS
    Last Post: 07-11-2006, 02:57 AM
  3. Software for controlling a TV media center
    By the_new_guy in forum Software & Software Development
    Last Post: 07-07-2004, 11:31 PM
  4. M10000 - Dead Dead Dead , 4 hours lol
    By Bikr in forum General Hardware Discussion
    Last Post: 05-23-2004, 02:37 AM
  5. List your software here!
    By PoBoy in forum Software & Software Development
    Last Post: 08-12-2002, 07:06 PM
