Results 1 to 10 of 11
Thread: making a BAT file?
    FLAC djmickyg's Avatar
    Feb 2004
    making a BAT file?
    hi,
    how do u i make a bat file using notepad that can open up a number of programs.
    and also controls if they load maximised or minimised
    thanks
    May 2005
    A pic is worth a thousand words.
    Feb 2004
    thanks was interesting... but it did say how to exicute an app? or maybe i missed it
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    same as running it from the command line. That's all a batch file does. If you wanna get a little more crazy with it, you may be better off with a visual basic script.
    Tidder
    Try RevFE
    Feb 2004
    dam i havent touched vb in about 5 years..
    i think i will stick with the bat file
    can i use a call command?
    call c:\.....exe
    Feb 2004
    well the call comand dont work
    but i figured u can just put the apps link in "" and it woks
    1 line like this
    "c:\Program Files\Winamp\winamp.exe"
    makes winamp open
    nice..
    Sep 2003
    New Mexico, USA
    yup, or use the 8.3 file names. like c:\progra~1\winamp\winamp.exe
    and I think you can still use the call command.
    Tidder
    Try RevFE
    Feb 2004
    nice one.. will try.
    also now do i make the dos window close automaticly after the winamp like has been read and winamp is open..
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by djmickyg
    Welp, I think due to the nature of batch files, it waits until the instance it created is closed before moving onto the next item of the batch file.
    How about you tell me what you're trying to do exactly, with which version of windows, and I'll see if maybe I could throw you together a quick vbs.
    Tidder
    Try RevFE
    Feb 2004
    i want to fun fordo as the shell
    then i want frodo to open the batch file which will open a number of apps
    make sence?
    and im using windows xp
    thanks
  1. EZSync Ini File Settings
    By ric355 in forum EZSync
    Last Post: 05-29-2005, 05:57 AM
  2. MPL File Encoding issue
    By itonylee in forum CF Bug Reports
    Last Post: 03-04-2005, 04:51 PM
  3. Help with a bat file
    By GARB-E in forum Operating System Optimization
    Last Post: 02-03-2005, 02:57 PM
  4. Can a bat file do this?
    By BLACKOUT in forum Software & Software Development
    Last Post: 02-22-2001, 04:21 PM
