Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Best option for booting?
  1. #21
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    that would probably confuse windows more than anything.
    Your everyday carpc geek and tech guru at your service. *bow*
  2. #22
    Apr 2005
    Queens, New York
    When I installed my nLited system...I created 2 partitions....the 1st partition with the OS on it which is 3gbs, and the other partition was the rest of the drive. So i installed EWF on the 1st partition. SO all my music and everything else goes on the 2nd partition so i dont have to disable EWF to add anything.....
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  3. #23
    FLAC SFiorito's Avatar
    May 2004
    actually you can use a boot.ini switch to max out memory...
    /maxmem=128
    That would trick XP into thinking you only have 128MB of RAM. I can't remember if I tried this or not with HORM (i.e. making a 128MB hibernation file and then resuming with full memory). Not sure if it'll work since you're resuming from hibernation and XP may still think you only have 128MB.
  4. #24
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    K, I had a chance to do some testing. Let me start by saying, these are in no way scientific. This is just the best I could do, with the stuff I had on hand. I also didn't use a stopwatch, I just used my watches second hand.
    A little about my setup.
    I am using XP SP2 with an AMD Athlon 1.2ghz processor. I have an ATI Rage 128 Video Card, and a Soundblaster Live 24 sound card. Of course, my MB also has sound on board. Connected to the computer is a Keyboard, a USB mouse, an unpowered USB Hub, to which was attached a Holux gm-210 GPS receiver.
    I had two different speed Hard drives to test. Unfortunately, they were not the same capacity, or even the same size. The 4200rpm HD is a 20gig IBM Travelstar 2.5 HD. The 7200rpm is a 80 gig Seagate Barracuda 3.5 HD.
    I used Acronis True Image to make a complete copy of the hard drives.
    I didn't use HORM. I setup the the OS to hibernate when I hit the power button. I then connected a push button switch to the header on the MB to both initiate the Hibernate, and to resume.
    I then started Road Runner (my current Frnt End) and started playing a song. I made sure that there was only one song in the folder that RR was reading for the music, to make sure RR wouldn't be doing anything like a DB of the songs or anything like that (Not sure if RR does that, but I made sure anyway)
    I then timed how long it took from me hitting the button, till I heard music from the speakers.
    I first list the memory specs, then the time for the 4200rpm HD, and then the 7200hd. So, lets get started.
    1)1x128mb 100mhz 24s 24s
    2)1x256mb 133mhz 28s 27s
    3)2x256mb 133mhz 31s 28s
    4)1x512 pc2100 31s 28s
    So, there it is. I am gonna start using the faster hard drive, and 512 megs of ram. I noticed when using just the 128, while it booted quicker, it had issues running the system. The difference between 256 and 512 wasn't all that significant to me, however, with the faster HD obviously is 3 seconds faster. Might as well be faster then slower for the same amount ofd memory, and maybe the faster HD will make the system a little quicker.
    Michael
  5. #25
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Just wanted to throw my two cents in.
    Disabling unneeded services can also speed things up and save some memory at the same time.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  6. #26
    Apr 2005
    Queens, New York
    How do you disable uneeded services
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  7. #27
    Jan 2005
    Warren, Ohio, USA
    go here
    for example. just off the top of my head, i can name quite a few services which could easily be disabled for a carpc environment:
    Automatic updates
    Fast User Switching Compatibility
    Help and Support
    Print Spooler (unless you plan to somehow use a printer with your carpc )
    again, these are just some of the services you can disable. the site i posted explains what each service does and will recommend a "safe" setting that you can set it to which isnt always what windows has it set at. of course, there are some in there (such as automatic updates) which arent even relevant in a carpc environment.
  1. Option A ? or Option B ? what do you think
    By tolisn in forum RR Skins
    Last Post: 06-15-2005, 02:52 AM
  2. Xenarc and AV2 first option
    By aguiu in forum LCD/Display
    Last Post: 05-31-2005, 07:19 AM
  3. OPUS 150 SFX Fan or XPC Fanless Casing Option
    By lostreception in forum Power Supplies
    Last Post: 05-27-2005, 04:39 PM
  4. no "exit to windows" option?
    By gutterslide in forum Media Engine
    Last Post: 02-11-2004, 06:23 PM
