Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Language to learn?
  1. #11
    Constant Bitrate elmo's Avatar
    Mar 2005
    Staffordshire, UK
    I would recommend c#.net as you already have VB experience you will find a lot of similarities between the two.
    I have experience on the following languages
    VB / ASP
    Visual C++
    VB .NET
    ASP .NET
    C++ .Net
    C# .Net
    J# .Net
    Delphi
    and for someone planning to get into programming i would only recommend VB, C# or Delphi, unless you have the cash to pay for a decent course that will give you a decent grounding in other languages, although saying that the resources are out there on the interweb
    www.streetrace.co.uk - The UK's best modified car club (With lots of 16/17/18 year olds for scouse to abuse)
  2. #12
    FLAC evandude's Avatar
    Mar 2005
    Maine
    okay, I'll look into C# then, thanks for the info. But I'd still like to get a few basic reasons why C# would be better for me than C++... since i don't really know much about C#
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  3. #13
    FLAC SFiorito's Avatar
    May 2004
    UI work in .NET (VB.NET and C#) is much easier to deal with and more powerful in the long run (since you spend less time dealing with the basics). I would download the new VisualStudio Express IDE's I linked in my first reply. Also, make use of MSDN. It has lots of information useful for both beginners and experienced developers.
  4. #14
    Mar 2005
    Maine
    Okay, cool. I downloaded the express IDE but the computers at work are running XP SP1 so I can't install it here. I'll have to play with it at home instead.
    eegeek.net
  5. #15
    Constant Bitrate Jeep's Avatar
    May 2004
    Sweden
    Go for C#, it's not that far from C++. And you don't have to wory about the boring part like memoty alocation and stuff, C# take care of that for you.
  6. #16
    FLAC J187's Avatar
    Nov 2004
    Boston
    You really can't go wrong with something like FORTRAN. It's quite simple and its the language of the future . . .
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  7. #17
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by J187
    FORTAN is the language of the future? Oh crap, I thought assembly was. Time to forget all the assembly I know and switch to FORTRAN
    Installed.
    -GPSSecure- - GPS Tracking
  8. #18
    Jun 2005
    I think that you should go with C++. You already know some and the only thing that you will have to get used to is .net. If you do learn something else in Visual Studio .net (VB or C#) there are many issues of not having enough control where you end up importing code from C++ or embedded Visual C++ (because it is unmanaged code so you have more control). Also another thing to consider is if you want to develop for a smart device (Handheld, cell phone, etc...), if you do then look at embedded Visual C++ (Free) because with the new .net 2005 you can port C++ from embedded into either VB or C# compact projects in .Net through a wizard which will make life easier than using PInvoke.
  9. #19
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Delphi... although I am a bit bias
  10. #20
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    Java. its an easy jump from c++. Netbeans is free from sun and u get a bunch of lib and api's.
  1. Replies: 44
    Last Post: 05-22-2009, 01:51 PM
  2. chinese language show as ???????????
    By bluehcc in forum CF Bug Reports
    Last Post: 01-27-2005, 01:42 PM
  3. Wanting to learn some programming, help me pick a language!
    By RS3RS in forum Software & Software Development
    Last Post: 10-15-2004, 04:38 PM
  4. what language to write program in
    By samael in forum Software & Software Development
    Last Post: 06-05-2004, 10:23 AM
  5. What Prog. Language for Programs?
    By dug1967 in forum Software & Software Development
    Last Post: 02-11-2004, 11:27 PM
