Results 1 to 10 of 13
Thread: Run Program When Wifi Detected
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Is There anyway of running a program using the command line when the computer connects to a specific wifi connection...
    I have map monkey log my trips and would like my syncronization program to run as soon as i pull in the driveway
    Debating on installing a carpc in my Jeep.....
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    good question ... im playing with replicators based on what ive found searching and want to auto replicate in the same way, infact both ways, car to home and certain folders home to car.
    Dec 2003
    Germany
    Well the simplest way to do it would be to have a scheduled script check every30 secs if SSID of the WiFi is the one of you home network and then run you sync script.
    I am sure there are tools out there that can do it. Maybe even ipconfig /all plus a decently set grep command will do the trick.
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
    Nov 1999
    Ishoej, Denmark
    If you are using dhcp, ipconfig may be part of the way.
    you might be able to use the command ipconfig > presentState.txt
    This will put the state (ip address etc) into the text file.
    There are several batch processors out there which should allow you to search the result file (presentState.txt) for ie the gateway address. ie(The Norton Utilities v6.X, known as Batch Enhancer)
    Possibly the for command could be used to do this.
    If found commence your copy / move command.
    Hope this helps a bit.
    Raw Wave
    Jun 2004
    On the beach
    Personally, I'd check for a connection on the Wireless connection in XP and detect which SSID is in use, if correct then run the script, quite easy to do in VB/VBScript.
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    I was working on some automation for work today and remember seeing a very short batch script someone had written to check for connection. If I find it again, I'll post the link. It's small enough that it could be set to run every couple of minutes. I don't think it would cause too much overhead since the script is so short (maybe 25 lines).
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Or JScript! This moves all files in a folder that don't exist on the homeputer after checking to see if it's there. I just call it every time the PC shuts off and it works if there's a connection.
    Code:
    function MoveFiles()
        var path = 'C:\\Video'
        var dest  = '\\\\RemoteComputer\\SharedFolder\\Video\\'
        var fso = new ActiveXObject('Scripting.FileSystemObject')
        if( !fso.FolderExists(dest))
            return
        var f = fso.GetFolder(path)
        var fc = new Enumerator(f.files)
        var name
        for (; !fc.atEnd(); fc.moveNext()){
          name = fc.item()
          var destfile = dest + fso.GetFileName(name)
          if( !fso.FileExists(destfile))
              fso.MoveFile(name, dest)
    Raw Wave justintime's Avatar
    Apr 2005
    Quote Originally Posted by djXternal
    Search web for BVRP Connection Manager Pro.
    It does exactly what you want (and much more)
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Aug 2005
    No one really specified the OS, so in linux case you can just add rsync information and a ftp address to it. Put the rsync:// in your ifup script and everytime internet comes up it runs it at end. Works pretty well for me
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I thinking of adding the reverse direction copying into the next release of my Playlist Update program, that would then do what you need.
  1. Is it possible to run every prog embedded?
    By memy in forum Road Runner
    Last Post: 02-13-2005, 07:19 PM
  2. AC97 Control Panel Switcher Program (could be useful for many)
    By Vinister in forum Software & Software Development
    Last Post: 02-02-2005, 04:50 PM
  3. How to run another program when Winamp is the Shell?
    By Genesis in forum Software & Software Development
    Last Post: 02-12-2002, 03:18 PM
  4. charchter lcd program?
    By Jaymz in forum Software & Software Development
    Last Post: 02-15-2001, 08:32 PM
  5. Can someone write me a PIC program 4 a awesome s/down controller please?
    By gizmos in forum General Hardware Discussion
    Last Post: 07-17-2000, 01:43 PM
