Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 84
Thread: Utility to change behavior of ATX power button (e.g.: launch an app)
  1. #11
    Raw Wave justintime's Avatar
    Apr 2005
    nice!
    But I just tried a shutdown /? command for all the provided switches, and I came to realize this cancels a SHUTDOWN sequence. Maybe it does work with hibernation too?
    Also, doesn't seem like I can use this SHUTDOWN command to initiate a hibernation. but I know of several other command line utilities that allow you to do that. We're getting closer!
    EDIT: This utility can initiate a hibernation via command line:
    http://www.slawdog.com/products/smartsd/
    EDIT 2: Well, I went ahead and tried the whole setup, but sadly the shutdown -a command does not apply to hibernation. Otherwise, IT WOULD WORK. Anyone know of a way to cancel hibernation using command line utils?
    Quote Originally Posted by Peoples
    a) invoking shutdown -a cancels hibernation, but i'm sure there is an api way to do it
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  2. #12
    Apr 2005
    Based on my research, it is easier to deal with intercepting/cancelling a shutdown sequence in Windows. SO at this point, I am pretty much convinced that the best approach is to set up Windows Power options to SHUT DOWN when the Opus sends a power button 'press', intercept the shutdown sequence (easy), run your script, and then send a hibernation command (easy)
    Thoughts?
    2002 Honda CR-V
  3. #13
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by justintime
    Thoughts?
    Yes that would be a way you could do it. If you wanted I could build something to do this pretty easily. Let me know exactly what you want (including any gui or setup) if you want me to make it. Would you mind if it was based on .NET or would you prefer not? I can do either way but .NET is easiest.
    Installed.
    -GPSSecure- - GPS Tracking
  4. #14
    Apr 2005
    Hey, thanks for offering man.
    I did find a utility that performs the exact task I was looking for, it is this utility called ActiveExit XP. It does a whole lot more than what I need it to, and unfortunatley at a pretty heft price: $30, and almost 3 MB of RAM. (ouch!)
    Here is a screenshot of the configuration piece that allows you to run a command upon hibernation. I tested this today, and it will halt the hibernation sequence until the program that you configure to run has closed (even if it takes 1 hour to complete). So it works well.
    I would love to see something like this for less $$ (preferably freeware of course), but most importantly something that doesn't eat up all that memory -- certainly don't need all the extra features!
    Anyhow, something is out there, and it works. Not really sure we need to waste your (or anyone's) time in re-inventing the wheel. If you are really interested in coding it though, I am more than happy to provide some basic software specifications and requirements. (at least what I envision!)
    Thanks!
    Quote Originally Posted by xBrady
    2002 Honda CR-V
  5. #15
    USA
    Ya, if you want something I'll throw it together. Hopefully I can get around to it before your trial expires
    Let me know if you want it to just run in the background or if you want a system tray icon. Also let me know what other setup stuff you want.
    Installed.
  6. #16
    Apr 2005
    OK, I'll keep it simple. Here are the requirements/specifications that I came up with according to my very specific need (but also very influenced by what I believe everyone else would need for a CarPC setup)
    -Application launches at startup (user can put it in Startup items)
    -User configures app to execute an application upon intercepting any given 'event'. Configuration is performed once, and saved in ini file.
    -Events that can be 'intercepted' are one or more of the following: Shutdown, Restart, Hibernate, Standby.
    -User can select an action for every event. If user wants the same action for every event, then he simply ties the same action to each one.
    -When an event is detected, the app will intercept it, cancel the event, and execute the corresponding action instead (typically,launch an application or execute a script, or whatever user configured). What's important is that after the script finishes executing, the app should NOT continue with the original event (i.e., it should not perform the shutdown or the hibernate etc. This was already cancelled). It is up to the user to handle this in the script. So if user really does want to continue with a hibernation after his script executed, he simply adds his own shutdown command at the end of the script. This gives the greatest amount of flexibility.
    -Option to minimize upon launch.
    That's really all we need. I can put together a mockup of what I envision this to look like tonight if you want me to.
    2002 Honda CR-V
  7. #17
    Apr 2005
    Hey Xbrady. Any word on this? Did you ever find time to put something together?
    Edit, here is a conceptual design. Even found a name for it!
    Any takers?
    Interceptor:
    2002 Honda CR-V
  8. #18
    Apr 2005
    OK, last try.... Xbrady, you there?
    Anyone else willing to code this if Xbrady doesn't?
    2002 Honda CR-V
  9. #19
    Apr 2005
    Bellevue, NE
    First, I would suggest adding a check box for the option of resuming the original event. This still gives you the option of doing it in code if you wanted to.
    Second, depending on my free time, I might take a crack at doing it. It would be in VC++ 6 since I don't have a copy of .NET and prefer not to have a copy. (Yeah, yeah, yeah. I'm an old school programmer. I cut my programming teeth on QuickBasic.)
    Just because I haven't posted alot doesn't mean I haven't searched and know what I am talking about!
    Progress Meter [███████████] 2%
    General layout design is done in my head. Just need the money to buy the stuff and start building.
  10. #20
    Apr 2005
    Noldona:
    OK, so you agree this would be tremendously useful when used in conjunction with an Opus?
    Thanks for at least giving it a try. Doesn't sound too complicated. (I used to program a long time ago, but never for Windows / x386)
    2002 Honda CR-V
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 05:53 AM
  2. Rewiring ATX power button
    By DCC in forum Power Supplies
    Last Post: 02-07-2008, 06:17 AM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. ATX board power??
    By Alphared in forum Power Supplies
    Last Post: 01-10-2003, 01:36 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
