Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 84
Thread: Utility to change behavior of ATX power button (e.g.: launch an app)
  1. #21
    Apr 2005
    Bellevue, NE
    The method to do it seems simple enough. Hook the WM_ENDSESSION and return 0 to cancel the shutdown, do whatever process you need to do, then call the ExitWindowsEx function. Using the uFlags parameter, you can set it to what type of shutdown/logoff you want.
    Only issues I see right now is how to pull the original shutdown/logoff type from the original WM_ENDSESSION message, and a possible infinate loop causing the puter to hang. I'm sure there is a way to grab the shutdown/logoff info, I just need to do some more reading. As for the possible infinate loop, that might be a bit more tricky to overcome.
    [brainstorming]
    If you set the shutdown part at the end of the script and immediately close the app after you start the script then it shouldn't do it. With keeping the shutdown option in the app itself, this would require the app to send the shutdown command and then close.
    [/brainstorming]
    Test will have to be made to see if that would be an issue.
    Now to learn how to do standard controls in C++. I grew up as a Basic programmer and have only recently gotten into Windows programming in C++. Most of my experience thus far is directed towards game programming though.
    Just because I haven't posted alot doesn't mean I haven't searched and know what I am talking about!
    Progress Meter [███████████] 2%
    General layout design is done in my head. Just need the money to buy the stuff and start building.
  2. #22
    Raw Wave justintime's Avatar
    Apr 2005
    If you dont want to waste time with the interface, how about a simple .ini or .xml file where we can configure all the settings? This doesn't have to be fancy, but it does have to be effective!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  3. #23
    Apr 2005
    Bellevue, NE
    Well, now that I am getting off of work I will see what I can do. I might just go the MFC route.
  4. #24
    Apr 2005
    Any update on this?
    2002 Honda CR-V
  5. #25
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    by the way I am pretty sure that the application named in the other thred can be allowed to last more than 20seconds, iirc 20s is the standard windows time to properly close an application, and this time can be changed or forced to infinite. I'm sure I've seen it somewhere, needs some searching.. will do :P
    that programs with autoit rocks
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  6. #26
    Apr 2005
    I guess I will have to learn how to code this myself. All in the sake of saving 3 MB of precious memory LOL!
    2002 Honda CR-V
  7. #27
    Apr 2005
    I know I keep on resurrecting this... not a chance in the world I would be able to code this, but there are a ton of talented coders in this forum. Anyone seriously willing to program this?
    Posts 16 & 17 have the relevant specs for the util...
    2002 Honda CR-V
  8. #28
    Jan 2003
    Ruston, LA
    Be done in a bit.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #29
    Jan 2003
    Ruston, LA
    Restart and Shutdown are the same thing, don't think I can differentiate.
    However, I can add an event for logoff.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #30
    Jan 2003
    Ruston, LA
    Hibernate and Suspend are the same as well.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 05:53 AM
  2. Rewiring ATX power button
    By DCC in forum Power Supplies
    Last Post: 02-07-2008, 06:17 AM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. ATX board power??
    By Alphared in forum Power Supplies
    Last Post: 01-10-2003, 01:36 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
