Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 84
Thread: Utility to change behavior of ATX power button (e.g.: launch an app)
  1. #41
    Jan 2003
    Ruston, LA
    Quote Originally Posted by justintime
    Another alternative.
    How about you find a way to differentiate between the 'normal' resumes from hibernate, and the ones you canceled via interceptor?
    For example, before canceling the event with interceptor, write a 'True' to a variable.
    After detecting a resume from hibernate, read the variable, if True then you do no launching, and set the variable to false. If it is false, then you launch the apps...
    You realize you just described the same thing.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #42
    Jan 2003
    Ruston, LA
    Release
    Here. Source Included.
    Attached Files Attached Files
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #43
    Jan 2003
    Ruston, LA
    You can use/modify that to suit your needs, however I have a better idea
    that I may work up later.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #44
    Raw Wave justintime's Avatar
    Apr 2005
    Our posts crossed paths in cyberspace LOL.
    Yeah, it is basically the same thing.
    Quote Originally Posted by frodobaggins
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  5. #45
    Apr 2005
    Frodo,
    First of all thanks so much for this!!!!
    Ok, so I gave it a spin on my Capruter (bench setup for now), and it is definitely intercepting and cancelling the hibernate event.
    However, it is not executing anything I set up in the fields. I even tried selecting your very own 1.bat script, and it is not writing to the text file as you'd expect. Tried several other apps, and nothing. I also tried with other events (shutdown for example) and no go.
    I am running a Biostar with Athlon XP2400+, 512MB Ram, and Windows XP SP2.
    Release
    2002 Honda CR-V
  6. #46
    Apr 2005
    NEVERMIND!
    I just realized that you have to close and re-open the app so it loads the new configuration...
    It works like a charm! Thanks you Frodo, this is awesome!
    If you ever plan on adding the 'start upon resume' feature, it would make this so powerful... but it is great as-is. Wow. woohoo!
    Frodo,
    2002 Honda CR-V
  7. #47
    Apr 2005
    Frodo,
    Task Manager reports over 4 MB of RAM usage for the Interceptor. Does this sound right to you? Sounds like a lot to me.
    (removed edit, and placed in new reply)
    2002 Honda CR-V
  8. #48
    Jan 2003
    Ruston, LA
    Frodo,
    No, that's about right for a simple VB app with a form.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #49
    Jan 2003
    Ruston, LA
    I'm gonna work up something a little different in a few days, please test it out
    for me when I do.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #50
    Apr 2005
    Frodo:
    The RESUME box seems to be reflecting whatever you set in HIBERNATE box. The INI file captures the correct path, but the front-end seems to display the wrong variable for the Resume box. Incidentally (and most likely related), RESUME doesn't really seem to be doing anything. Is this the action to execute after coming back from a hibernate?
    2002 Honda CR-V
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 05:53 AM
  2. Rewiring ATX power button
    By DCC in forum Power Supplies
    Last Post: 02-07-2008, 06:17 AM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. ATX board power??
    By Alphared in forum Power Supplies
    Last Post: 01-10-2003, 01:36 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
