Results 1 to 8 of 8
Thread: Gamepad interface code
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Does anyone have some example VB6 code (DirectX or otherwise) for interfacing with a usb gamepad? I've searched - no joy.
    Mobile Impact Creator reddeath30's Avatar
    Mar 2005
    Fontana, California
    What are you going to use it for? There might be an easier way to accomplish what you need.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
    Super Moderator xBrady's Avatar
    USA
    Frodo has some. In fact he built a plugin that you might be able to use if you want your program to run of the FrodoCom network.
    Installed.
    -GPSSecure- - GPS Tracking
    Feb 2005
    Bellevue, WA
    Have you checked the MSDN guides for DirectInput?
    Tutorials on DirectInput should be readily available on the web. I believe VB6.0 tutorials and samples last shipped with the DirectX9.0 SDK after that they moved over to VB.NET
    Jun 2003
    Chester Springs, PA
    Yes I saw all the DirectX examples, but they only mention joysticks. So a gamepad will be recognized as a joystick, correct?
    OK that makes it simple. Thanks for the help.
    BTW I want to use the gamepad to remotely control a robot. It's not a carPC - it's a PC car so it's sort of on topic. It will be something like this or more like this since I'm using an RC car as the base and mounting an EPIA on it. Control will be via WiFi with the gamepad on my desktop PC.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Constant Bitrate Jeep's Avatar
    May 2004
    Sweden
    Yes, gamepad is a "joystick" in DirectX.
    Don't forget that you must configure your gamepad in windows controlpanel first before "read it" via DirectX.
  1. GPS/MapPoint VB Source Code
    By stevieg in forum Software & Software Development
    Last Post: 01-28-2011, 04:59 PM
  2. My VB code for Elm interface! OBD2
    By infinkc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-29-2009, 11:22 AM
  3. XMdirect cable + Sony Unilink Interface. help!
    By d2.n in forum General Hardware Discussion
    Last Post: 03-17-2005, 04:36 PM
  4. I2C (not SMBus) SW interface for M10k?
    By rando in forum Software & Software Development
    Last Post: 09-14-2004, 02:59 PM
  5. ultra tiny interface
    By skullman in forum Input Devices
    Last Post: 03-22-2004, 03:53 PM
