Results 1 to 7 of 7
Thread: Hibernation enabled, can't hibernate with Power Button
    Jul 2005
    Canada
    I've got a problem with making my power button hibernate. Now before you go tell me to , listen up, I have, and my problem is different. Unless it really isn't, then please at least post the link to the appropriate post, cuz I can't find it.
    I've enabled hibernation, I can hibernate no problem by going through the start menu, but in my power > advanced settings, I don't have an option of selecting what happens when my power button is pressed. Now I've tried various BIOS settings to make it work, and nothing. The closest I get is by changing this one setting in BIOS labelled "PM Managed by APM", (no more info than that, I'm assuming it stands for "Power Management managed by Advanced Power Management", though I could me wrong) which has options Yes and No. When at Yes, pressing the power button in Windows halts my system for a few seconds, then continues like nothing happened. When at No, pressing the power button gives me a hard shutoff...
    But really that doesn't get me any closer to hibernating at button press...
    I've been searching the microsoft knowledge base, but nothing, all those articles assume you have the "When I push the power button on my computer..." Menu already there...
    One more thing, I installed XP while ACPI was disabled in Bios, I've enabled it since then, but it did nothing... right now I'm updating XP through windows update, if that doesn't work I'm gonna try reinstalling.
    System:
    Old Slot1 Mobo
    P2 200MHz
    256 Ram
    Installed XP SP2
    Thanks, any help, however randon and way out there, I appreciate it.
    Tercel96
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I'd say xp left out some stuff because ACPI was off... try re-installing it...
    make sure you have ur display drivers working (although I think this is nothing to do with it since you see the hib option in power management)
    Roy
    2005 Range Rover 4.4
    Jul 2005
    Canada
    Yeah, the windows update did nothing for me, so I'm gonna try reinstalling it... But damn, installing XP with a 200MHz processor is a pain! Thanks for the advice...
    Tercel
    São Paulo, Brazil
    Yeah, living with a 200mhz mustnt be too quick either
    Roy
    Jul 2005
    Canada
    Wow, reinstalling windows actually worked! So Now I can successfully hibernate at the push of a button, thanks... And as for living with a 200mhz, I'm just gonna put it in my car to listen to mp3's the old school way (lcd screen, keypad), so 200 is enough for that. Alright, back to work!
    Tercel96
    Elsewhere
    You have to have ACPI setup the way you want when you install Windows so that it detects the available options fromt he BIOS and installs available components.
    I'm certain this could be worked around by hacking the registry and installing components, but I don't know how to do it.
    How about the Wiki?
    Nov 2004
    You Need ACPI, APM won't do what you want to do. Motherboard is too old. ACPI came out in 1998. Try looking for a BIOS update for your mobo.
  1. Powering PC With Power Button Instead of Automatic Power
    By legend5761 in forum Power Supplies
    Last Post: 04-17-2008, 11:41 AM
  2. No more power button cable hacking!
    By MikeH in forum MacCar
    Last Post: 05-19-2005, 11:12 AM
  3. I want to add a power button on my dash. Which can i use?
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 10-25-2004, 04:17 PM
  4. power button
    By EggrollXpress61 in forum General Hardware Discussion
    Last Post: 08-14-2004, 05:26 AM
  5. Wanting Epia to go to hibernation with power switch.
    By jnusaira in forum General Hardware Discussion
    Last Post: 06-21-2004, 01:46 PM
