I can just talk for my Siemens S65 but I have to push the left button on my phone to hand the audio from the phone to the pc. maybe you have that option as well![]()
Hi, I'm newbie and I need your help...
I didnt' find any solution in the other posts so I've decided to post a new one.
I'm trying to use the Nokia 6600 handsfree services with my pc using this USB Bluetooth. The connection seems established, because I see the handsfree local service connected and the Nokia handsfree audio gateway connected to the 6600
If I try to call my 6600 from another phone I can see the call on my Pc but when I answer with the Pc I can't hear anything. It's the same thing when I try to listen an audio file from the Nokia to my pc. Can someone help me please?
my widcomm drivers are
4.0.1.700 of11/05/2004
my 6600 firmware is
V 5.27.0
28-06-04
NHL-10
Thank you very much
Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
Download the German Voicepack 1.0 for FreeDrive now!
Most likely you need a newer firmware version for your 6600 - that's what I ran into when trying to implement the bluetooth audio gateway stuff - from searching I read that Nokia's bluetooth implementation for the hands free stuff kind of sucked at first but was patched somewhat with the later firmware. At that point I said f it because I don't know anywhere local that can do the fw upgrade and I can't send my phone off for who knows how long to have it upgraded. Of course keep us informed if you find out anything new!
I think you have the right, however I have wrote an email to Nokia support where I had explain the trouble. Now I'm waiting for an answerOriginally Posted by Zac
It's incredible, I asked at the Nokia Help online an they told me that they don't know this problem![]()
My 6600 with latest firmware (5.53) not working! :-(Originally Posted by maxzor
Renault Megane II Berline 1.5 dCI Dynamique Plus 2004
Epia SP13000, HDD 40 Gb, CarTFT MM400 7" touchscreen, SB Audigy 2 (PCI), Terratec Cinergy 600 TV/FM tuner, M1 ATX
Gigabyte USB BT dongle, X-Micro Wlan USB stick
Globalstar BR-353 USB GPS
You should persist.
I had got a 6600 too and I successfully connect it ti Pc via bluetooth with Trust BT dongle and WINDCOM drivers. But i remember had tried since day to make it working.
I wonn't be able to remeber how I done because that makes a long time but you should try on several PC because sometimes there are uncompatibilities with the dongle.
