Results 1 to 10 of 12
Thread: iGuidance and Frodoplayer display issues?
    Variable Bitrate wallaceacura's Avatar
    May 2005
    SE Wisconsin
    I've searched and haven't found anything quite like the problem I'm having. I'd keep searching but it's almost 2am and this 7" Lilliput is killing my eyes.
    Only once out of every 10 times does iGuidance display properly in Frodo. I've tried to hide/unhide start/restart etc. and play with all of the settings. Still no luck. It's not unbearable, but I know it can be fixed. The screenshot shows the black bar between song title and the screen.
    I've read about iGSkinner and the new SKinner program, but it seems a little too complex for me. Has anyone used it with Frodo? Is there a FAQ for settint it up?
    Thanks in advance.
    May 2005
    SE Wisconsin
    one more thing
    I forgot...I'm using iG 2.0.1. Also, frodo doesn't check the nag screen for me anymore. It did early on, though? I think I wore the damn thing out?!!
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    iGSkinner and SKINbedder will not work with FP
    BTW: I think that FP has to get rid of the nag screen, otherwise it won't embed properly. I had the same issues with iGS and Sb.
    May 2005
    SE Wisconsin
    Nag screen
    Am I missing a setting to get it to remove the nag screen? I just finished reinstalling everything thinking I might have messed something up and same issue. Does it matter that I'm using an nLited system? Same problem with full install though.
    What is SB?
    Jul 2004
    Berkeley, CA
    I'm pretty sure that FP needs to get rid of the nag screen to embed correctly. Something is wrong with your system or settings. Check your settings again.
    Sb = SKINbedder.
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Ever since I went to IG 2.1, I have the same exact problems (both of them - Proper embedding and no nag) as wallaceacura has. It was working fine with Routis 2004 and IG 2.0.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    May 2005
    SE Wisconsin
    I'm using 2.0.1 if it helps. Is that just different enough from 2.0?
    What settings should I be looking for? I've poured over the .ini file trying to find something that I've missed. Anyone else overcome this problem?
    Jul 2004
    Berkeley, CA
    Hmmm.... here's what I'd do. There's a registry entry that disables the NAG screen. You need a progam that writes that entree and launches iG... and then does not terminate.
    Elsewhere
    Quote Originally Posted by 0l33l
    Hmmmm.
    I wonder if any of the suers here has written such a program. Boris, do you know if anyone has?
    How about the Wiki?
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by DarquePervert
    Hmmmm.
    No. And that's why people have been switching from FP. He decided to hardcode the classname
  1. Replies: 2
    Last Post: 05-03-2005, 03:54 PM
  2. iGuidance Embedded
    By voidunknown in forum FrodoPlayer
    Last Post: 01-09-2005, 05:19 PM
  3. Replies: 0
    Last Post: 11-27-2004, 06:47 PM
  4. Iguidance not embedding ?
    By NRGZ28 in forum FrodoPlayer
    Last Post: 11-23-2004, 04:56 PM
  5. iGuidance launcher app
    By Envitro99 in forum FrodoPlayer
    Last Post: 11-23-2004, 04:53 PM
