Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
Thread: Active Noise Reduction
    Maximum Bitrate Mañana's Avatar
    Jul 2004
    Sweden
    I just came up with a thougt.
    How about placing a microfone somewhere in the car, and then hooking it up to the computer. Then let the computer monitor the sounds in the car (enigne noise etc), and then you let the program send exatly the same signals to the speakers, but inverted. That would eliminate the noise and you'll get rid of (well, it'll probably not work 100%) all the noise! =D
    I know this already has been made, you can buy earphones that work this way, but still... Wouldent it be cool?
    Also, you could let it monitor any music that the pc sends out, so that it wouldn't try to get rid of it...
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I don't know anything about this Active Noise Reduction thing, but it sounds really cool. I would how effect it would be.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I'm not sure if the speakers we use today are capable of sending that "inverse" sound wave...
    But yeah, it is basically the principle in noise-canceling headphones, and even the noise canceling equipment available on some private jets (I guess some airlines might have it already by now, it has been available for private jets for more than a couple of years)... basically it emits an "inverse" of the "noise" it captures. I think it wouldnt be easy though, as I believe it "predicts" the noise pattern based on the noise it has been hearing. That is how it can send the inverse-noise simultaneously with the "noise"...
    It probably wouldnt work very well accelerating or changing speeds/RPMs, but should be pretty cool at constant speeds.
    Roy
    2005 Range Rover 4.4
    Jul 2004
    Sweden
    Quote Originally Posted by RoyN
    They do =)
    I think it wouldnt be easy though, as I believe it "predicts" the noise pattern based on the noise it has been hearing. That is how it can send the inverse-noise simultaneously with the "noise"... It probably wouldnt work very well accelerating or changing speeds/RPMs, but should be pretty cool at constant speeds.
    Do you think that it'll need a buffer that big that it can't keep up with an accelerating engine?
    Constant Bitrate gizak's Avatar
    Feb 2004
    Phoenix, AZ
    I've thought about this too as a way to combat surrounding noise being intrusive to voice control programs. It must be hard to do or somebody would have it made already right?
    -GiZak-
    Carputer Project: 98% Complete!! *tweakin'*
    Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
    São Paulo, Brazil
    What do you mean "buffer too big"... the buffer is like maybe the last .5 seconds or something... however, when accelerating there is a change of "constant background noise pattern", and until the noise stops changing the results will not be as good...
    it wont completely stops working as you accelerate or anything, but its efficiency is really with "constant background noise" that is the whole principle. it copies the constant noise, and sends out a inverted sound wave of that noise.
    Pretty cool, who has it already?
    Roy
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    That's a great idea! I'm going to build this into a hat, so that it cancels out repetitive droning music. Watch out Enya!
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    No expert by any means, but I thought one of the big challenges was the multiple paths sounds takes to get to you.
    A headset/mic is relatively easy as you dealing with pretty much fixed positions. Whereas in a car, the sound is coming to you from various paths. (direct, deflections)
    Unless the speaker was on or near your ear, it's not going to hear the same sounds that our ears do, so any inversion you do won't cancel (or completely anyway) out the noise. Something like that would probably be much easier to do with earbuds as they are at the same location and could invert in realtime. (Combining the headphone jack with what's coming in from the other side).
    I played with it a little while back trying to cancel the noise from my fans in my cpus. I only screwed with it an hour or two, but it did get me thinking about it.
    Jan 2005
    UK
    I drive a Ferrari - why would I want to cancel out the engine noise?? !!
    Agree with the previous point though - I wouldn't expect it to work unless the device was placed in or very near to your ear.
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    The reason this is concept is exploited so handily in headphone form is that..
    » Noise comes from many different places places. Calculating the offset for the inverse signal is complex w/o also calculating distance to the ear. --let alone more ears (other passengers)
    •Micke
  1. Noise (from engine and other sources) HELP!!!
    By sstylos in forum Car Audio
    Last Post: 09-20-2005, 12:41 PM
  2. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 10:31 AM
  3. noise investigation
    By lookinco in forum Power Supplies
    Last Post: 09-23-2004, 02:41 AM
  4. Noise!! AARGH!
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2004, 01:33 PM
  5. Line Noise Reduction: Suggestion
    By VanMan69 in forum Car Audio
    Last Post: 06-07-2004, 11:47 PM
