Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Does this exist? automatic file transfer software?
  1. #11
    New York
    i thought EZsync was just for client/server connections. Will it auto detect the usb key and transfer the files to the local folder? Itunes wont work because i'm not just transferring music.
    Check out this thread from the EZSync Section. This implementation is in works for what I believe is the next build. But don't quote me on that.
    EZSync Thumbnail Drives
    Mark
    Website: http://www.greenpowerenthusiast.com/
    Car'Puter Project
    - Xenarc 700TSV
    - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
    - 1x 256MB Corsair XMMS DDR400
    - M2-ATX
    - Belkin 802.11G W-Nic
    - Garmin 15H GPS
    - WinXP SP2 (NLited)
  2. #12
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    yeach, RR interchange is one that springs to mind...
    another option is making an autorun file... for it, it is probably the easiest if you want to copy everything to a fixed directory....
    this may help:
    -http://autorun.moonvalley.com/
    -http://www.ashzfall.com/products/autorun/
    -http://www.ashzfall.com/products/autorun/autorunfloppy.html (autorun on floppy drives / and enabling autorun on different drives memo sticks?altho I think memosticks already play autorun)
    Roy
    2005 Range Rover 4.4
  3. #13
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    since i already use ezsync for my wireless updating i spose i'll wait til the next release when this is implemented. Thanks!
  4. #14
  5. #15
    Woodbridge, VA
    Blog Entries
    53
    That program looks interesting! This may be just a stab in the dark but does it by chance automatically add songs to a playlist. For example, i want all my rock songs in one playlist so i can load them via button press in rr... but that would require me to add songs to play list each time i add songs to my hard drive. Does your progam do that?
  6. #16
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Sonicxtacy02
    If you are talking about mine, it just copies files for files.
    IE you specify what location you want the files copied from and what location to and it copies like for like.
    the source and destination can be anywhere, same PC different drives, on a USB stick, or on another PC that you connect to via LAN or wireless lan.
    Basically there is a check file that the program checks for periodically (this can be changed,check the readme) when it is found it then compares files stucture and files and either copies or deletes to make them the same.
    Note to self maybe I need to add an option to not delete
    if you were not refering to mine, please disregard this post.
  1. Automatic Sync Software *Suggestions*
    By cheerio in forum Software & Software Development
    Last Post: 10-05-2004, 02:33 AM
  2. myHTPC Software
    By the_new_guy in forum Software & Software Development
    Last Post: 06-05-2004, 03:51 PM
  3. A new software in devloppment - NEOCAR
    By netsuo in forum Software & Software Development
    Last Post: 05-05-2004, 05:48 AM
  4. Software to show activated switchs exist???
    By syclone477 in forum Software & Software Development
    Last Post: 04-13-2004, 02:24 AM
  5. Replies: 3
    Last Post: 12-28-2002, 10:47 AM
