Results 11 to 20 of 26
Thread: AIMEE Climate Control POLL
  1. #11
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    Quote Originally Posted by RoyN
    Dancehaven let me go out and say this, even though you didnt ask...
    My using of Aimee or any other frontend is not based on Climate control. Although "nice" to have an integrated package I fear how complicated it would be to hook the whole thing up... I also understand a lot of moving around would be done and that I would lose my original control (possibly forever if I needed to hack it up/solder/desolder)...
    I know you said FUTURE VERSIONS, but I sure as hell hope the release isnt being delayed because of adding this sort of thing...
    These are always very true points to consider
    To be able to complete such an install its no lie that you will need to be very competent with a soldering iron and have a good understanding of basic electronics, i.e swicthes and motors
    And rest assured AIMEE is not been held back while we implement this feature mainly because its already implemented
    its the hardware that is still work in progress hence why im gathering information
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
  2. #12
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    Has anyone actually looked at what is actually connected to the AC controls? Just to give you a heads up. Other than fan speed. Many vehicles use vacume lines, valves and cables to control Heat and AC. This is even true for many high end vehicles.
    So without knowing preciesly what is under the dashboard, the answers to the guestions asked above could be very misleading.
    Then you have other issues like dual zone, single zone, does the car have memmory settings for driver passanger? Does the system control the compressor and heating valves directly or is that processed by HVAC control unit?
    Face it guys to make this work on anything other than your own vehicles you will have to have test vehicles at your finger tips from different models, manufacturers and years.
    Either that or it will have to be a generic relay control hack that basically engages and disengages a relay bank at the touch of a on screen button. And that is already available. In addition it will still have to be a custom install for about every vehicle.
    How do I know this? Because for I worked on Rolls Royce, Jaguar, Mercedes, Rover, and other imports as a professional mechanic for a number of years.
  3. #13
    New York
    Vehicle = Hyundai
    Year 2001
    Air Con = Yes {All Electronic, No Manual Strings/Vacs at Interface}
    Climate Control = No
    AIR CON
    Air Con Button = Yes
    RECIRCULATE
    Recirculate button = Yes (Recirculates cabin air rather than use road air)
    FAN SPEED SETTING
    Up and Down Buttons = Yes
    4 positions
    Rotary Switch with hard limit = yes
    Note: Please complete number of positions for Fan adjustment
    TEMPERATURE CONTROL
    Temperature Range in degrees C = 17-30 in 0.5 Steps
    Up and Down Buttons = No
    Rotary Switch with hard limit = Yes
    Have to check count in the technical documents. Get back to me on this if needed
    VENT POSITON CONTROL
    Number of positons = 5
    Number of Vent buttons = 1 (I.e a Mode button that cycles through vent locations)
    REAR WINDSCREEN DEMISTER
    Button = Yes
    Timeout = Yes
    Mark
    Website: http://www.greenpowerenthusiast.com/
    Car'Puter Project
    - Xenarc 700TSV
    - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
    - 1x 256MB Corsair XMMS DDR400
    - M2-ATX
    - Belkin 802.11G W-Nic
    - Garmin 15H GPS
    - WinXP SP2 (NLited)
  4. #14
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Vehicle = BMW 328i
    Year 1997
    Air Con = Yes
    Climate Control = Yes
    AIR CON
    Climate control Button (Sometimes shown as AUTO) = Yes
    RECIRCULATE
    FAN SPEED SETTING
    8 positions
    Rotary Switch with hard limit = No
    Rotary Switch with no hard limit = No
    Mechanical Slider = No
    Electronic Slider = No
    TEMPERATURE CONTROL
    Temperature Range in degrees C = 16-35 in 0.5 Steps
    Up and Down Buttons = YES [Dual one for passenger and driver side]
    30 positions
    Note: Please complete number of positions for temp adjustment
    Number of positons = 3
    Number of Vent buttons = 3 + AUTO (I.e a Mode button that cycles through vent locations)
    FRONT WINDSCREEN DEMISTER
    As one of the Vent Postions = No
    Button = Yes
    Timeout = No
    Button = Yes
    Timeout = Yes
  5. #15
    May 2002
    Essex, UK'er
    Quote Originally Posted by accentsound
    Very imformative post
    But this ofcourse is what we have been researching for several months
    Mastero has already created a standalone Climate control system using our
    software. that is already in production and avaliable to buy
    hes proven it to work on many vehicles and has based the design on that
    fact
    Obviously this isnt for everyone and only the super competent may consider
    to undertake this install.
    However the system will be super flexable to allow you to do this
    www.aimee.cc
  6. #16
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    accensound you miss the point I think... although there are all those complex types of interactions between HVAC control unit and HVAC compressors, etc, the control units follow some sort of standard.... basically knobs/buttons/sliders, etc...
    from what I understsand this project owuld be able to control the control unit, not replace it! so again, it will work on most units I gather...
    doing it directly would be basically impossible... tka emy car for instance, the control unit speaks to a AirCon ECU, which only then commands the compressor... the protocol for airconecu->control unit comm is of course proprietary... but emulating a button press on the control unit is very much simple...
    correct me if I'm worng Dancehaven, but this is how I think your gonna do it right?
    Roy
    2005 Range Rover 4.4
  7. #17
    May 2002
    Essex, UK'er
    SPOT ON
    To a certain extent
    To be totally hohnest based on what research we have already conducted
    theres not that much to it!
    Its a case of measureing and monitoring temp sensors and controlling various
    outputs and motors based on the temp readings.
    Theres no reason what you couldnt replace the entire system with this unit
    www.aimee.cc
  8. #18
    São Paulo, Brazil
    what I'm saying is that you wont need to interface to complex things like vacuum hoses, etc...
    Roy
  9. #19
    May 2002
    Essex, UK'er
    Essentially yes
    If people need to be able to drive a motor directly or fit a servo to control a
    mechanical slider then the module will also allow this
    www.aimee.cc
  10. #20
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Vehicle = Peugeot 306 with Auto Aircon
    Year 1997
    Air Con = Yes
    Climate Control = No (auto mode)
    AIR CON
    Air Con Button = Yes with LED indicator. Also auto on when windscreen selected for demisting
    Climate control Button (Sometimes shown as AUTO) = Auto position on fan speed dial
    RECIRCULATE
    FAN SPEED SETTING
    Rotary Switch with hard limit = Yes - many positions + auto setting using mechanical feel. Control interface via poteniometer on PCB
    Dial angle: approx 120-150deg
    TEMPERATURE CONTROL
    Temperature Range in degrees C = 21 deg setting only - others are colder or hotter
    Angle: 270deg from max tempt to min temp with 21 deg at approx 150 deg.
    Rotary Switch with no hard limit = no
    Number of positons = 4 (screen, main vents + screen, floor, main vents) - potentiometer interface to pcb for activating A/C etc + mechanical rotary cam connected to 2 cables
    Number of Vent buttons = 0
    Angle: 270 deg.
    As one of the Vent Postions = Yes
    Button = No
    Timeout = No
    Button = Yes
    Timeout = Yes
    If there is anything i have missed please let me know so i can update my post
    Rotation angle for dials
  1. Climate control through pc
    By SweetLikeChutny in forum Hardware Development
    Last Post: 04-06-2007, 11:36 AM
  2. FS - Custom Audi Lilliput & climate control surround
    By Tha Hombre in forum Classified Archive
    Last Post: 01-15-2006, 07:30 PM
  3. climate control with carputer
    By mac2k6 in forum Hardware Development
    Last Post: 11-03-2005, 06:15 PM
  4. Digital Climate Control
    By Fatigue in forum General MP3Car Discussion
    Last Post: 02-14-2005, 08:01 PM
  5. climate control
    By john_draws in forum General Hardware Discussion
    Last Post: 06-27-2004, 11:31 PM
