what kind of cable would need to be used to utilize this feature?
As you all may know the every impending release of AIMEE is only a matter of light years away....
Myself and Garry have been looking at possible features for future advances and
improvments in later versions,
one of those proposed features is a AIMEE controlled climate control system
What we need is some feedback to see who would be interested in such a system
Also to cater for everyone we need to know how your current Air Con / Climate Control
system currently works
As you know all manafactures do it there own way
So We need some feedback for the following options / configerations
Note:Tthe final product will come with full wiring and instructions to install
However some people will need external servos and mechanisms to control any mechanical parts of there stock system
Please Complete as appropiate
Any Comments or things we may need to know, please put in closed brackets at the end of the relevant line
Example:~
Vehicle = Mitsubishi FTO
Year 1995
Air Con = Yes
Climate Control = Yes
AIR CON
Air Con Button = Yes
Climate control Button (Sometimes shown as AUTO) = Yes
RECIRCULATE
Recirculate button = Yes (Recirculates cabin air rather than use road air)
FAN SPEED SETTING
Up and Down Buttons = Yes
8 positions
Rotary Switch with hard limit = No
Rotary Switch with no hard limit = No
Mechanical Slider = No
Electronic Slider = No
Note: Please complete number of positions for Fan adjustment
TEMPERATURE CONTROL
Temperature Range in degrees C = 17-30 in 0.5 Steps
Up and Down Buttons = No
Rotary Switch with no hard limit = Yes
30 positions
Note: Please complete number of positions for temp adjustment
VENT POSITON CONTROL
Number of positons = 5
Number of Vent buttons = 1 (I.e a Mode button that cycles through vent locations)
FRONT WINDSCREEN DEMISTER
As one of the Vent Postions = No
Button = Yes
Timeout = No
REAR WINDSCREEN DEMISTER
Button = Yes
Timeout = No
If there is anything i have missed please let me know so i can update my post
Cheers Guys![]()
Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
www.aimee.cc
I would suspect that USB would work but I think that firewire would be much faster and give you better response in changing the temperature and fan speed.![]()
[/OFF TOPIC]
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Vehicle = Chevy G20 Van
Year 1990
Air Con = Yes
Climate Control = No
AIR CON
Air Con Button = No
Climate control Button (Sometimes shown as AUTO) = No
RECIRCULATE
Recirculate button = No (Recirculates cabin air rather than use road air)
FAN SPEED SETTING
Mechanical Slider = Yes (4 positions ))
TEMPERATURE CONTROL
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
Vehicle = Range Rover
Year 1999
Air Con = Yes
AIR CON
Climate control Button (Sometimes shown as AUTO) = Yes (1 button)
RECIRCULATE
FAN SPEED SETTING
Rotary Switch with no hard limit = Yes (1 setting for both sides)
TEMPERATURE CONTROL
Temperature Range in degrees C = 16 - 30
Up and Down Buttons = yes (1 "rocker" switch (up/down) for each side passenger/driver)
Number of Vent buttons = 1 for each (single mode for both zones - 1 setting applies to all)
Button = Yes
Button = Yes
Roy
2005 Range Rover 4.4
Originally Posted by ProphetX
Currently the prototype is RS232 controlled,
Hence a 9 way D Type Serial Cable
But you could also use a USB to RS232 Convertor to enabel USB access
Furture versions will be USB Controlled
The amount of data that is communicated is tiny so there will be no need for
Any high speed link (firewire / USB 2) etc
www.aimee.cc
Dancehaven let me go out and say this, even though you didnt ask...
My using of Aimee or any other frontend is not based on Climate control. Although "nice" to have an integrated package I fear how complicated it would be to hook the whole thing up... I also understand a lot of moving around would be done and that I would lose my original control (possibly forever if I needed to hack it up/solder/desolder)...
I know you said FUTURE VERSIONS, but I sure as hell hope the release isnt being delayed because of adding this sort of thing...
Roy
Vehicle = VW Jetta
Year 1991
Air Con = Yes
AIR CON
Air Con Button = NO
RECIRCULATE
Recirculate button = NO (Recirculates cabin air rather than use road air)
FAN SPEED SETTING
Rotary Switch with no hard limit = Yes 4 Positions including OFF
TEMPERATURE CONTROL
Number of positons = 4?
As one of the Vent Postions = Yes
Button = Yes
Timeout = Yes
Yo andrew...Originally Posted by Danceheaven
Be careful what you say, I know exactly whats going on in this project![]()
Originally Posted by Chris31
Dont know what your talking about![]()
www.aimee.cc
