Results 1 to 10 of 10
Thread: nlite didn't do anything
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    I just nlited an install down to 240 mb/600 mb footprint. I have booted 4 times since then and all boots are over 1 minute. I have made no other changes, but i would expect to see improvements after nliteing xp down to half of its size. I have a via m10k. Will I see improvement after a few other tweaks.
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    May 2005
    Vienna, VA
    You have to disable some services to see boot time improvement.
    Feb 2005
    S Ohio
    like what?
    My NEW carPC
    May 2005
    Vienna, VA
    don't know. search for more info. also check this out.
    http://www.tweakhound.com/xp/xptweaks/supertweaks1.htm
    Feb 2005
    S Ohio
    I disabled a bunch of services (about 15-20) and saw no improvement in boot time, i did a before and after and it was 64 before, and 65 seconds after. I don't think that after a 240 mb nlite install i should be above 50 seconds even with a ****ton of services running. any other advice?
    My NEW carPC
    May 2005
    Vienna, VA
    defrag the drive
    try bootvis to determine the time consuming processes
    Jan 2003
    Ruston, LA
    Reducing size does nothing for boot time. You need to optimize.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2005
    S Ohio
    good to know, i ran bootvis and optimized, and it took like25 minutes to optimize, but it took off like 5 seconds. How much do ewf and minlogon help?
    My NEW carPC
    Feb 2005
    S Ohio
    so 42 seconds of my boot time is spent in the "disk" section. You know when you run bootvis, there is the first bar graph with drivers, disk and so on... Most of my time is spent loading the "disk" does anyone know how to make this go faster other than by clicking optimize?
    My NEW carPC
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Faster HD? although I see your already with a 7200
    Roy
    2005 Range Rover 4.4
  1. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 06:41 AM
  2. nLite XP ? and performance
    By NJ_Jackals in forum WinNT Based
    Last Post: 10-13-2008, 02:53 AM
  3. Touchscreen problems with nlite and minlogon
    By Ascension in forum WinNT Based
    Last Post: 06-01-2005, 06:18 AM
  4. Nlite Build and SAPI
    By TheJack in forum WinNT Based
    Last Post: 04-21-2005, 06:51 PM
  5. Nlite to CF card?
    By SlashEMc2k in forum WinNT Based
    Last Post: 12-25-2004, 03:22 PM
