Results 11 to 20 of 29
Thread: Found! Nice Nintendo emulaor that's touch screen friendly
  1. #11
    Jul 2005
    Aw I thought I was the first.
    Why are you using FCE? I looked at it but it didn't have a gui menu?
  2. #12
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    Quote Originally Posted by slightlystoopid
    In the FCE version I use an embedded explorer window to display the files...
    If you read about my RockNES X version you'll understand why i put it away, but if v3 will be able to catch the RockNES X fullscreen window i think I'm going back to it...
  3. #13
    Jul 2005
    Ok I remember reading that post. I didn't have the full screen problem. I just leave the resolution at 640x480 so it is easy to get back to gps/music tabs.
  4. #14
    Super Moderator xBrady's Avatar
    USA
    Nice work, I'd love to see you do emulators for other systems too.
    Installed.
    -GPSSecure- - GPS Tracking
  5. #15
    Jul 2005
    Other systems? You mean other emulators?
    Using skinbedder I am sure rocknes could be used with any frontend.
  6. #16
    USA
    Ya, sorry I meant other emulators.
    Installed.
  7. #17
    Jul 2004
    Sweden
    Quote Originally Posted by Maņana
    Because because if i tell RockNES X to launch the roms in fullscreen, it launches fullscreen and not "fullscreened" in the small panel window. Mybe fullscreen uses another window name? Cant capture it, the whole thing hangs upp if i try to look at au3info while playing in fullscreen.
    It has another windowname in fullscreen, "RockNES X Full Screen Window" but changing that doesnt help. Class is also "RockNES X Full Screen Window", but that doesnt matter either...
    I Meant i was not able to capture the full screen window.
  8. #18
    Jul 2005
    I am not sure what I am doing different but I am able to control the window.
    I go into Rocknes and change the screen resolution to 640x480 then in the options there is something that says let run in window mode. I close Rocknes and the settings are saved.
    I start skinbedder and it embeds nicely.
    My front end runs at 800x600 so I start the emultor right in the middle and it looks good.
    I had some problems with the program hanging so I made an autolt3 script that goes out and kills skinbedder. I made a custom button and used
    run(kill.exe) to lauch the script when it is pressed.
  9. #19
    Jul 2005
    Yeah I would like to find a nice GBA emulator.
  10. #20
    Jul 2004
    Sweden
    Okay, well thats what I had to do too, but i dont want to. Explanation in this post: [Release] SKINbedder BETA 2.99999
    I also made a kill file in the end, it seems to not be willing to close down once you've played a rom. if you just start skinbedder without starting a rom it will close perfectly... Only difference is that i had two kill commands with a wait command between.
  1. Can't calibrate lilliput touch screen
    By _wd in forum LCD/Display
    Last Post: 02-14-2007, 10:10 PM
  2. Touch screen friendly NES emulator
    By warnockm in forum Software & Software Development
    Last Post: 01-05-2005, 09:39 PM
  3. touch screen size
    By Bump in forum LCD/Display
    Last Post: 12-20-2004, 10:08 AM
  4. Someone pease help me. Cd touch screen?
    By dallasyoung in forum General Hardware Discussion
    Last Post: 12-14-2004, 10:55 AM
  5. Touch screen friendly cd ripper
    By vipergda in forum Software & Software Development
    Last Post: 11-19-2004, 11:17 PM
