Page 22 of 101 FirstFirst ... 12131415161718192021222324252627282930313272 ... LastLast
Results 211 to 220 of 1001
Thread: One-Click WebCam Recording!
  1. #211
    May 2005
    Vienna, VA
    Man I'm thinking maybe someone could write a game where you can "shoot" other cars that appear on this web cam viewer as you drive by. Bonus points if you shoot a cop!!! That'd be fun for the passenger. Probably need a lot of CPU power for the image processing piece though.
  2. #212
    Constant Bitrate Prefect's Avatar
    May 2005
    Switzerland
    Wouldnt it be a cool idea to overlay current speed in the frames?
    Thats number one of my list since I started with Capture!... Maybee I have time in this summer break.
    b8bboi: And what will happens with the car if you shot it down? Why not combine that with a roof-mounten video-projector and beam the bullet-holes directly to the cars infront of you...
  3. #213
    Constant Bitrate Goddy's Avatar
    Dec 2004
    Netherlands
    Another cool thing to do: an option to 'delay' recording. Like one frame every second with a playback of 30 frames/second. In that way we get movie of an one hour trip in about 2 minutes.
    This will result in smaller movies, lower cpu power, cool/easyier movie to playback.
  4. #214
    May 2005
    Switzerland
    Jup! I want that too :-) The problem is, that you cannot set a different playback-speed at the time of recording. You have to speed-up the movie afterwards at your home-pc with virtualdub.
    You can set recording to 1fps in the config.ini. But your camera has to support it!
    I think you know this video I made: Capture_Zeitraffer_x25_25fps_wm9.avi (right-click and save to disk...)
  5. #215
    May 2005
    Switzerland
    @All: New Version: Capture!.zip
    You can now define 4 Shortcuts:
    Start/Stop
    Exit
    Archive Video
    Switch Input Source
    Switch Input Source: Please test this function. I do not have a capture device with multiple inputs. I need detailed error-messages and problem descriptions.
    Archive Video now checks if the destination folder exists. If not, the video is backuped to the capture-folder.
    Some bugfixes: Detect errors while recording could have looped infinitly. Now max. 10 approaches are made, then give up.
    Regards! Chris
  6. #216
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by Prefect
    Start/Stop
    Exit
    Archive Video
    Switch Input Source
    Regards! Chris
    Well,I test this!
    Mauri
  7. #217
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    Looks good !! When changing the inputs i do however get this error, it seems to be on the 4th button press.
    Hope this helps.
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
  8. #218
    May 2005
    Switzerland
    Ok, but the first three 4 sources (0-3) work?
    So I have to set the limit to (VideoSpourceCout-1).
  9. #219
    Sep 2005
    I've only tested 2 inputs as i only have 2 cameras, but it certainly switches between them fine.
    Excellent work.
    Steve
  10. #220
    May 2005
    Switzerland
    I uploaded a new version which cicles through the input devices from zero to (inputdevicescout-1).
    I think that should work better for Tissy.
    Please try and report bugs!
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 09:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 07:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 11:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 04:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 01:27 AM
