Page 27 of 102 FirstFirst ... 17181920212223242526272829303132333435363777 ... LastLast
Results 261 to 270 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #261
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Quote Originally Posted by Ashthos
    Re: Cameras..
    I was using a el-cheapo Nightvision one from ebay. It had rubbish exposure and white balance (i.e. too light during the day, too dark during the night). Since then I have got one of the new silver PS2 Eyetoys and the winxp drivers. Apart from having to manually set the video size (352x288) in the config I cannot fault it. Its exposure is excellent meaning it copes well with bright sunlight and going into tunnels etc.
    Would thoroughly recomend it and it only cost me a few quid from Ebay.
    I could post some videos if anyone wanted to see a sample but they are rather large...
    Ash
    Post some vids
    ````` _____||.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
  2. #262
    Feb 2005
    Video Divx ~11mb - Done from the rear view mirror of my Celica.
  3. #263
    Nov 2004
    St Louis
    I thought you said this camera was looking forward, if so you're driving on the wrong side of the road.
  4. #264
    Constant Bitrate Prefect's Avatar
    May 2005
    Switzerland
    @Ashtos: Thanks for your words!
    When you say, it doesn't record anymore, do you mean it stops recording or is the video when you watch it too short or something?
    I once had a similar problem when i used divx or xvid. I recorded 30 minutes but the resulting avi file was only 8 minutes long. Weird problem.. :-/
    Cool video! I go to England this summer and have to drive a rental car. This way I can get used to driving on the wrong side ;-)
  5. #265
    Variable Bitrate Tim Lake's Avatar
    Oct 2005
    Bedford, UK
    I think you mean the correct side!
    You crazy foreigner
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Bluetooth, 802.11g, GPS
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    NLited XP with Road Runner and MapMonkey
  6. #266
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    I get an "error while setting up the capture object" "the parameter is incorrect" the second time I try to start the app.
    The first time I try it, it works, but it just records black AVIs. My Webcam is a Nortex NX Vega with both VFW and WDM drivers available (I am using WDM) that is only capable of 352x288
    Any suggestions?
  7. #267
    May 2005
    Switzerland
    You can try set the 352x288 directly via the config.ini.
    Try choosing a different video codec.
    Set the framerate to 10, 15 or 25 fps.
    So you say it works for the first time? But after you saved settings and restarted it gives you that error?
  8. #268
    Lum
    Lum is offline
    Jan 2005
    Liverpool, England
    It doesn't work as such the first time. It starts without errors, but then saves blank AVIs
    Subsequent starts, even if I wipe the entire install and unzip it again, give that error. I have to reboot to get rid of it.
  9. #269
    Jul 2005
    I'm just curious about what kind of CPU usage people are getting when running Capture.
    I'm on an SP13000 mobo (512mb RAM) and, while capturing, my CPU usage climbs to over 75%. This is with my brand new PS2 eyetoy cam (which is awesome by the way...thanks to all for the suggestion!). Don't get me wrong though....the video capture looks great, but the only problem is that other applications (especially running Navigation or something) really take a hit. The map refresh is way slower and other apps take WAY long to load.
    I tried capturing with a few different codecs, and surprisingly, DivX gives the lowest CPU usage. Others are upwards of 85%.
    Is it just that my mobo isn't fast enough, or am I doing something wrong here? Do others run capture behind their frontend (CF, RR, Streetdeck) successfully?
    Thanks in advance!
  10. #270
    May 2005
    Switzerland
    You have a SP13000 System! This is about as fast as a PentiumIII 500mhz! Don't suggest to much from the via systems.
    I have a MII10000 and no matter what I do it is to much for the system. Thats why I ordered a CoreDuo 1.83Ghz 1GB RAM CarPC. This is about 10 times faster than the via system. I want to run two instances of Capture! and have FreeDrive for navigting without any lags.
    Bottom line: 75% CPU usage for Capture! is very good! :-)
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 09:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 07:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 11:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 04:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 01:27 AM
