Page 3 of 100 FirstFirst 1234567891011121353 ... LastLast
Results 21 to 30 of 997
Thread: One-Click WebCam Recording!
  1. #21
    Constant Bitrate Prefect's Avatar
    May 2005
    Switzerland
    Haha thanks JC ;-)
    (cool list! saw it for the first time now *g*)
  2. #22
    Variable Bitrate Bodgy's Avatar
    Nov 2003
    Briz Vegas, Australia
    Works great on my home pc, but I do get an error when I try to change options -> audio source.
  3. #23
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    The program works great at home! Thanks a lot!
    Here are the settings I'm running:
    Cam.: Ezonics P35U+
    Res.: 640x480 @ 30FPS
    Audio: none
    Compressor: DivX® 5.2.1 Codec
    I'll be installing this in the car tomorrow to see how it runs in action.
    Bugs/Suggestions:
    Although I'm viewing and recording at 640x480, Video Device Capabilities (Options-->Video Capabilities) is still showing 320x240.
    Would you be willing to make the start button a start/stop button (i.e. when you press start, the button turns to stop and that way I won't have to look for the stop button on the other end of screen while driving)?
    Is there a way to create a "background.jpg" file so that the user could change the background to any picture he/she likes? I understand that you really like your RX-8, but most of us are in this hobby for the "cool factor." It's not really cool to have someone else's car show up on their screen.
    Not sure if it's a bug, but there's no titlebar in full screen mode.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  4. #24
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by Gobby
    Shame it needs DotNet
    Ya, I'd also like to know what is so shame about it needing .NET.
    Installed.
    -GPSSecure- - GPS Tracking
  5. #25
    May 2005
    Switzerland
    @Bodgy: i get the error too (newer tryed that before ) i'm looking into it.
    @DJiK:
    Quote Originally Posted by DJiK
    --> i'm checking that. i think the menu has it own defaults, regardless what you set in the config.ini. i think i have to rebuild the menu at startup for showing the correct settings
    --> first i had this configuration. but then i wanted the stop button seperate to prevent accidently doubleclicks on the start-stop button. (clicked stop and accidently started again) we should start a poll for that question
    --> sure, sure! thats clearly an extension i want to integrate. customisable background-images. i just don't know yet how to integrate .jpg images right out of the C# code (right now the image is integrated in the .exe)
    --> thats not a bug set it to "normal" and start it fullscreen via your carpc software if you want a titlebar.
  6. #26
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Just make the double-click event do nothing, or put disable on the button that is released after a delay of half a second or something...
    Just an idea.
  7. #27
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by Prefect
    Noob!
  8. #28
    May 2005
    Switzerland
    Arrow
    new Version: Capture!.zip (or use the link on the first post, they are the same )
    new features:
    • one big button for start AND stop
    • higher buttons (sometimes the windows taskbar was overlapping the buttons)
    • customizable background image!! just save your own "background.bmp" to the programm folder. only bmp works till now.
    • smaller file size because the background image is no longer integrated in the exe.
    @DJiK: on my system the menu is showing the tick correct at 640x480 if i set the following in the config.ini:
    FrameSizeHeight = 640
    FrameSizeWidth = 480
    @Bodgy: i can reproduce the error. but i can't locate the problem in the code till now. i have to work on it tomorrow..
    regards! chris
  9. #29
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by xBrady
    EPIA motherboards - thats what!
  10. #30
    Raw Wave
    Jun 2004
    On the beach
    I refuse to install .NET on my CarPC ... it grinds to a halt, I don't even have it on my Desktop .... .NET seems to slow everything down even when just installed.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 09:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 07:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 11:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 04:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 01:27 AM
