Page 30 of 102 FirstFirst ... 20212223242526272829303132333435363738394080 ... LastLast
Results 291 to 300 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #291
    Constant Bitrate Friedrice's Avatar
    Jul 2006
    Thailand
    download works, now just have to wait to try this when i get home. Thanks Prefect!
    Rep! Rep! My kingdom for some rep!
    My WIP
    Ghetto Carlaputer: (putting things together) 0% * * * * * * * */2 - - 100%
    Wife's patience: 0% * * * */2 - - - - - 100%
  2. #292
    Constant Bitrate Prefect's Avatar
    May 2005
    Switzerland
    To speed up the video use VirtualDub. I don't remeber the exact steps I took but with a bit of trial and error you will get there:
    First step: reduce the frames to 1/25th. Option in VirtualDub is "process every ___ frame" and set it to 1fps. Save the video.
    Second step: Speed up the video to 25fps. Save the video.
  3. #293
    Constant Bitrate Goddy's Avatar
    Dec 2004
    Netherlands
    Maybe someone can make a batch of it
    Btw, Prefect. Do you think you are able to make a speedlabel (or any other customizable RR-label?) overlay while recording the video? That could be a cool option
  4. #294
    May 2005
    Switzerland
    customizable RR-label? hmm sorry I don't know RR and this labels.
    I tryed to overlay the video with text (speed, rpm and so on) but I can not make it record that to the video. I would need to write my own WDM-Videofilter and integrate that in the DirectVideo graphrenderer. Thats a bit too complicated for me :-/
  5. #295
    Low Bitrate ScarFace's Avatar
    Sep 2005
    This is a great tool, thanks .......... I find that the audio is delayed though, do you think using another audio codec will solve this ?
    Cheers.
    View the 260 Galloping Horses: [images]
  6. #296
    May 2005
    Switzerland
    I have the same problem here. Switching the video-codec does affect it. Xvid is much less delayed than Divx for me. I don't know what is causing that...
  7. #297
    Low Bitrate jasonsjwou's Avatar
    Sep 2006
    KOREA,USA,AUSTRALIA
    Would it be possible to record all the time (as soon as carputer starts, until it shuts down/hibernates), keeping only the last 30 minutes of video?
    i.e., Say I start the engine at 9AM and turn the engine off at 10AM. When the engine is turned off, only the last 30 minutes of video (Video from 9:30 to 10) are kept in the HDD. Of course, this can be 30 minutes, 3 minutes, or 300 minutes, customizable setting.
    I don't know if there are such softwares available, but if there are, please let me know.
  8. #298
    May 2005
    Switzerland
    Thats possible with Capture!
    Again:
    Set "Stop after X Seconds" to 1800 (30 mins)
    Set "Only Keep the last X Files" to 3
    Set "Autostart capture on load"
    If you use hibernate then set "Stop capture on suspend and restart on resume"
    At any time, you will have at least the last 30 minutes on tape.
    If something interesting happened, press the "archive video" button and the last 30 minutes will be permanently stored to any folder you declare.
  9. #299
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    Hey Prefect can I make a request? Is it possible to have an option when the program is minimized to only have a small icon on the system tray instead of the usual bar on the task bar? Is this too much work? Thanks for the great program.
    BTW I recently got an external USB capture device from plextor that has hardware DIVX encoder inside it so with NO compression on the computer I capture video in DIVX with 15-20% CPU and I have an SP13000!!! very pleased!
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5 SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  10. #300
    May 2005
    Switzerland
    Hi Spaceskater
    I'll add that to my todo list!
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 09:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 07:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 11:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 04:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 01:27 AM
