Page 31 of 102 FirstFirst ... 21222324252627282930313233343536373839404181 ... LastLast
Results 301 to 310 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #301
    Constant Bitrate spaceskater's Avatar
    Feb 2005
    Boston,MA
    Thanks Prefect!
    Will never be DONE! There is always something to add
    VIA EPIA SP13000,1GB DDR,80Gb 2.5 SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
  2. #302
    Low Bitrate com2soft's Avatar
    Sep 2006
    this sound so great. my web cam just need a workable piece of software.
  3. #303
    Constant Bitrate Prefect's Avatar
    May 2005
    Switzerland
    Exclamation
    @All: New Version! Capture!.zip
    And for your convenience: DualCapture.zip
    This includes two instances of Capture!, one preconfigured for the front-camera and one for the rear-camera. You have to configure your desired paths, codecs, videodevices and every other thing for each instance seperately.
    Here are the changes I made in this version:
    - Changed the timestamp in the avi-filename to "CarPC 2006-10-15.avi", so the files are always sorted correctly in your explorer after filename.
    - Added a NotifyIcon in the systray. Clicking on it, will toggle the visibility of the Capture! window. Starting hidden does not work right now (I don't know why...)
    - Added an option to auto align Capture! above the windows taskbar or to use the full height if the taskbar is hidden.
    - Added an option to set the free space in pixels on top of Capture!. So your external program shortcut bar of your favourite carpc frontend can fit in there.
    - Shortened the mainmenu text to fit two capture instances side by side on a 800x600 screen.
    - Set the status lable to transparent so you can see more from your background image and all the infos are displayed.
    Please report any bugs!
    Regards, Chris
  4. #304
    Mar 2005
    Sweden/Vaxjo
    well this looks like a sweet piece of software... I'm gonna try it tomorrow...
    I noticed reading through the thread that more ppl have asked about it, is there any other way to speed up the video then doing it afterwards... I've dreamed of filming my 13hr trip I take a couple of times each year to my parents and show it speeded up...
    can u set the fps to something like 1 while recording and then afterwards set it to 25... the files should be a lot smaller since it only needs to save one each second instead of 25...
    Swedish site for CarPC's
    http://www.bilpc.info
  5. #305
    May 2005
    Switzerland
    Hi Naesstrom
    You can do that! No problem. Speed up your 1fps-video with VirtualDub afterwards. Takes only seconds to re-code your avi.
    Regards!
    Chris
  6. #306
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by Prefect View Post
    Hi Naesstrom
    Regards!
    Chris
    Great... any tips on where I set the fps... is it in this software or should I check the settings of my cam... gonna try it when I drive to work next time...
  7. #307
    May 2005
    Switzerland
    You should start the software at least once before asking questions ;-)
    Its in the menu of Capture!. You can set different fps rates from within the menu. Or edit the settings.ini manually. Your Webcam and the codec has to support the desired fps, otherwise you will get an error.
  8. #308
    May 2005
    Switzerland
    Screenshot from DualCapture:
  9. #309
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Sweetness. I'll be checking this out tomorrow. The last version was working great, esp now that I'm running a microatx mb with an athlon 64 3400+ even though I'm using a usb capture device with software encoding... lol Now just to install my hardware encoding capture card
  10. #310
    lambosprit's Avatar
    Sep 2006
    UK
    Anyone know why using two eyetoys (one front, second rear) causes my system to crash. Can use each seperately but not together. Dont know if its this app or just a general problem. Great app by the way.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
