Page 37 of 102 FirstFirst ... 27282930313233343536373839404142434445464787 ... LastLast
Results 361 to 370 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #361
    Constant Bitrate Prefect's Avatar
    May 2005
    Switzerland
    Hi 0okami
    This is the latest version, the same like in http://www.iteconomy.ch/public/Capture.zip and http://www.iteconomy.ch/public/DualCapture.zip you can download on the first post of this thread.
    Works fine if you run it from the \CaptureTest\bin\release\ folder
    *lol*, you are shure you know how to deal with the source-code?
  2. #362
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    Quote Originally Posted by Prefect View Post
    Hi 0okami
    Me? Naa not at all. i'm not good at coding.
    you just seemed unsure if VisualStudio C# Express 2005 was required to be on the machine. Or maybe i misunderstood you.
    ~0okami.Digital
  3. #363
    May 2005
    Switzerland
    You need VisualStudio C# Express 2005 for opening and compiling the code (the .sln solution-file).
    The bin folder you found is just a "temp"-folder with the left-overs from previous compiling-tests.
  4. #364
    Feb 2006
    USA
    Ah, good to know. Thanks for explaining that. I hope someone can add some overlay info (GPS coords., speed, date and time.) that would be sweet.
    Looking forward to that.
    ~0okami.Digital
  5. #365
    May 2005
    Switzerland
    Me too! 8-)
  6. #366
    Oct 2007
    Thanks prefect
  7. #367
    Oct 2007
    Prefect, I remember reading you were following a lead on how to overlay text on the video. Can you tell me how far you got on that?
    Im going to try to add text for GPS coordinates and other info from RR.
    If anyone else is going to try the same or want to chat about it let me know.
  8. #368
    May 2005
    Switzerland
    I used this classes for Capture!:
    http://www.codeproject.com/KB/direct...txcapture.aspx
    They have a new version which would be nice to implement in Capture!. I think this would fix the sound-async-problem (which annoys me personally).
    Making a video-overlay is very difficult. You really have to be into directx and all the video-graphs. You have to make a bitmap image with the correct video-parameters and insert it into the capture-graph at the correct spot. So you will have to split up the capture process into single steps and do all the conversions and encoding manually. This also is very performance-critical.
    Regards!
    Chris
  9. #369
    Oct 2007
    Regards!
    Chris
    Im already building a diff from your source and theirs. The directx.capture class should be easy to replace with the new one. The capturetest class will requiere some work to determine what you changed on the original to make those same changes on the new one.
    So far it seems we can do overlay by using a SampleGrabber filter and then merging the video frame and a bitmap with the text already inserted and then saving the merged frame instead of the original one.
    I have no experience on directX so I guess this is one of those things that sounds easy but can be very hard to actually implement
  10. #370
    May 2005
    Switzerland
    I don't think I have changed something in the capturetest class by myself.
    It was the first C# project I did and at first I started by only modifying the form-proportions. So the code is veeerrry messy *shame*. But this could be an advantage: All the code from me is in the same main-class. It is just one long file that uses the capturetest classes.
    That where my thoughts too.
    That's what I experienced ;-)
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
