Page 38 of 102 FirstFirst ... 28293031323334353637383940414243444546474888 ... LastLast
Results 371 to 380 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #371
    Jan 2009
    any news about that overlay function ??
  2. #372
    Oct 2007
    Quote Originally Posted by moreause View Post
    well, I managed to make a mess of the code but still no closer to having the overlay on the video.
    I did update the support classes with newer code available on the project page but that didn't help on adding overlay
    We need someone with above intermediate knowledge of directx/directshow to look at the code and make the changes needed.
  3. #373
    May 2006
    Calgary, Alberta
    So this is Windows only then? I thought I saw one around for Linux, was pretty sure it was this one. Is there a similar one that works in Linux?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  4. #374
    Oct 2007
    Quote Originally Posted by Maheriano View Post
    This is based on .net and I dont think the MONO abomination can run it so you wont be able to run it on linux.
    I expect to migrate the carpc to linux at some point in the next few months. If you find any good web cam video recorder for linux let me know. I already migrated my main laptop to fedora 10 and everything is working great.
    Check the linux sub-forum and the LinuxICE section
  5. #375
    Newbie Cameleon's Avatar
    May 2007
    UK
    Quote Originally Posted by silvi4000 View Post
    Did you use the newer code on the DirectXCaptureRefresh project ( http://www.codeproject.com/KB/direct...reRefresh.aspx ) or the original project Prefect used. The refresh seems to be newer, but still doesnt look to have been updated since 2007. I was looking into learning C# (did Java for 4yrs at university) and trying to put it into a CF plugin when I started to get bogged down in all these different versions of the stuff! The most up to date I can seem to work out is to use the DirectXCaptureRefresh (which is on DirectShow.NET 1.5/VS 2005) and update it to use DirectShow.NET 2.0/VS 2005, which was last updated in 2007.
    At present I dont have a clue how DX works, but I like the idea of trying to get it updated, then into a plugin, and also get overlays working. With CF you can access the OBDII plugin which can give the nice overlay stuff like speed, rpm, etc.
  6. #376
    Oct 2007
    Quote Originally Posted by Cameleon View Post
    heres a link from when they tried to organize the project. I used the newer clases from the same project page. The refresh one didnt seem to have anything that could make the overlay any easier to implement
  7. #377
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I don't believe you can use SampleGrabber to modify the video stream. It's designed to decode a frame and copy it into a bitmap buffer which you can then do anything you want with it (detect commercials, video levels, save still image, etc.) but it's not really inserted into the graph like a true filter.
  8. #378
    May 2007
    UK
    Sorry, cant see a link
    With the newer DirectShow.NET on Sourceforge, they have examples of using SampleGrabber to overlay stuff. In one example they put a watermark onto the captured file and on another they read a file and overlay text onto it. The methods used in both look very similar, so I would guess you could use the text one with the watermark one to put text overlay into our captured video file. I thought getting it all up to date would be a good start then we can move from there on overlays and making it a CF plugin. I tried to just drop the newer DirectShow.NET dll into the Refresh project but it doesnt run, so I guess they changed some function calls between v1.5 and v2 which is a shame, I hoped it would be drag and drop. Doing a diff on the CaptureTest of refresh and the Capture! program code, they look very similar and I think the Capture! one can be dropped straight into the Refresh. I will test that tonight and see if it compiles/builds.
  9. #379
    Oct 2007
    I should never skip preview when posting......
    heres the link:
    http://directxcapture.wikidot.com/
    Inserting the customized CaptureTest into the captureRefresh project would be the easiest way. I though about doing a diff between the original CaptureTest and prefect's CaptureTest to extract the changes. Then it would be a matter on inserting the code in the correct places in the CaptureRefresh class without having to worry too much about the rest of the code. Prefects customization deal with the form design and file handling mostly so they wont get affected by any function changes in the video capturing methods.
  10. #380
    May 2007
    UK
    heres the link:
    Cool, thanks.
    I was bored at work yesterday and was doing diffs between various versions. I think all Prefect changed was the actual CaptureTest class when he updated it. I'm sure he said that somewhere in this thread about doing all his changes in the main class and it was messy. The differences between the original CaptureTest and Prefects CaptureTest are the same differences between the CaptureTestRefresh and Prefects CaptureTest, so integration should be a simple drag and drop.
    I have a track day coming this weekend and new seats delivered tomorrow, so cant see I will make much progress the rest of this week, but definately will try and stick Prefects CaptureTest class into the CaptureTestRefresh.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
