Page 46 of 101 FirstFirst ... 36373839404142434445464748495051525354555696 ... LastLast
Results 451 to 460 of 1001
Thread: One-Click WebCam Recording!
  1. #451
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Here's what I last had: http://curioustech.home.insightbb.com/Capture.zip
    The GetSize is in VideoCapabilities.cs
  2. #452
    Oct 2007
    Got the PS3 eye working with now. For some reason it was half working. The ps3 eye demo application would work but the AMcap.exe that came with it and capture wouldn't recognize the device. Reinstalling solved that.
    Will try your last zip tomorrow.
    I guess flipping the GPS info will be needed if the image flipping occurs after the merge/overlay, right?
  3. #453
    Newbie Cameleon's Avatar
    May 2007
    UK
    Glad you got it working. From what I knew neither me nor Curiosity had changed anything to do with the device selection, so when I saw your post I was at a bit of a loss!
    Curiosity: I see in your Compass program, you have breadcrum trails. Would it be possible to add something like that to this app using the GPS filter? Not thought about how it would work, but would be cool if you could make it take up one of the corners or something.
  4. #454
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by silvi4000 View Post
    Yes. Unless you wanted upside down text. I have to copy the frame (bottom-up) anyway, so figured I may as well add 3 more routines in there.
    Quote Originally Posted by Cameleon View Post
    I'll see what I can do. I don't really like the way I wrote that code. Truncating offscreen polygons and all that. I think I could only do it from the start of capture too, as it's hard to load and save data.
  5. #455
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    one thing..the time in the software is GMT? it is 3 hours behind here in greece a setting for that would be ok..or o setting to get the time from the system instead of GPS maybe?
  6. #456
    Mar 2004
    Florence Yall, BFKY
    It's converted to local time using the system timezone and the format uses your locale settings.
  7. #457
    Oct 2007
    Quote Originally Posted by Curiosity View Post
    I get the same compilation error after applying either of your last 2 zips.
  8. #458
    Apr 2006
    Greece
    ok i will check it out..but i am sure i have the correct timezone in the carpc..thanx
    EDIT: i checked it out the timezone is correct.. so there must be something wrong with this..
    the same happens to my vista notebook here and XP in the carpc!! (3 hours behind) this is strange!
  9. #459
    Mar 2004
    Florence Yall, BFKY
    They're all the same zip. I used WinDiff to merge Cameleon's changes. The current files in there are:
    Capture.cs 4/24/2009 10:19 AM
    CaptureTest.cs 4/23/2009 7:52 PM
    VideoCapabilities.cs 4/23/2009 2:05 PM
    Quote Originally Posted by Nomader View Post
    Did you get the one after I added local time conversion? It's only been 4 days.
  10. #460
    Apr 2006
    Greece
    Right, well this will keep you guys happy! (maybe)
    http://www.cingram1.plus.com/mp3car/...timate_0.1.zip
    You need to download xport and the GPS filter from Curiosity's site to get the GPS filter installed. Not sure what it will do if its not installed, I havent tried it! I though I would just get this out there so people can see what can be done. I am not a professional coder so dont expect any or all bugs to be fixed. I will try my best, but we may have to stick it on SourceForge or something to keep it moving. I have had problems when testing it going from preview to no preview to capture to no capture etc (trying to break it, it did break!). This mainly happens with preview with capture. Also to get turn off audio on preview, you need to click the setting and restart. Need to sort that really.
    Have fun
    i am using this one.. can't find another built version posted..
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 09:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 07:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 11:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 04:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 01:27 AM
