Page 47 of 101 FirstFirst ... 37383940414243444546474849505152535455565797 ... LastLast
Results 461 to 470 of 1001
Thread: One-Click WebCam Recording!
  1. #461
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I made changes to the filter about 3 or 4 times
    http://curioustech.home.insightbb.com/dsgpscode.html
    The latest .exe is in this zip as well
    http://curioustech.home.insightbb.com/Capture.zip
    It was tested with and without the filter, but you have to disable it in the ini to not use it.
  2. #462
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    I replaced the exe with the one in the zip above..it runs ok but you can not enter into the submenus..look the arrows are missing
    but time works ok
    EDIT: i tried the original version and time is ok..looks like it was the filter needed updating
  3. #463
    Mar 2004
    Florence Yall, BFKY
    Oh that's odd. Usually when there's an error every menu item is ghosted and the arrows are gone, like when I forget to plug the cam in. But this one works with all the cams I've tried. Did you get any errors at all?
  4. #464
    Apr 2006
    Greece
    Quote Originally Posted by Curiosity View Post
    yep this one ath the beginning. the cam works ok ..but i have no way to check if the audio is selected ok
    EDIT: ok fixed it.. i selected -1 in the config file for the audio device and it is ok now
    EDIT2: Now it is not working again.. no matter what..the same error and the menus are gone
  5. #465
    Mar 2004
    Florence Yall, BFKY
    Oh that's my GetSize method again. I guess that's in DirectX.Capture.dll
    Ok, I put that in the zip file (link above). Sorry, still getting used to this compiler.
  6. #466
    Newbie Cameleon's Avatar
    May 2007
    UK
    Probably just easiest to stick everything in there
  7. #467
    Mar 2004
    Florence Yall, BFKY
    Haha, yeah. I wasn't thinking that far ahead.
  8. #468
    Apr 2006
    Greece
    redownloaded..and still the same error!
  9. #469
    Mar 2004
    Florence Yall, BFKY
    That's the right DLL for sure. Maybe there's another instance if it somewhere else.
  10. #470
    Oct 2007
    Now that overlay is working we should try and merge all changes to build a new setup.
    I tried to merge the files that have been posted but failed with the error I previously posted.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 09:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 07:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 11:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 04:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 01:27 AM
