Page 50 of 101 FirstFirst ... 404142434445464748495051525354555657585960100 ... LastLast
Results 491 to 500 of 1001
Thread: One-Click WebCam Recording!
  1. #491
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Hi yorky, sorry I missed this.
    The only error I get is when I don't set the audio device to -1 in the ini. The default frame rate is set to 30 in the ini for me, and it shows that in the program when I start up but it may be dropping for some other reason. The frame rate depends on a lot of factors, like on mine it drops to 10 if I use 640x480, but can get 30 for 320x240. Also I can't get it to start with ffdshow set to xvid but it works great with H.264 and some others.
  2. #492
    Dec 2005
    Perth, Australia
    Audio device to -1 doesn't effect the error
    Seems to record perfectly fine when I manually select 30fps BUT dies with an error (which I should screenshot) if I try and record again and have to close and re-open the program Anyone come across that issue?
    Cheers!
  3. #493
    Mar 2004
    Florence Yall, BFKY
    I found the problem with the frame rate and posted an update here:
    http://curioustech.home.insightbb.co...reUltimate.zip
    I did get an unspecified error and found that it was because the audio device wasn't set. Once that was set, I tried recording at 15, 25, and 30 fps. It seemed to work without closing and reopening at least.
  4. #494
    Newbie Cerberus's Avatar
    Nov 2003
    Some great work here! Cheers for the efforts guys!
    A favour if I may? The thread is a bit long and confusing in places.
    Is there a particular post or set of posts that will give me an Idea
    what components to download and how to configure. In order to
    get Capture running with one camera and GPS overlay.
    Or failing that does anyone have time to throw together a quick
    'how to' ?
    Cheers!
    C
  5. #495
    Nov 2003
    Ok.. So I had a play......
    Downloaded the zip (3 posts previous)
    Downloaded xport
    Plugged in GPS, Connected it to xport, Got satelite fix.
    Run Capture from capturetest/bin/release
    Throws an error -> Object reference not set to an instance of an object
    Hit 'continue'
    Capture opens and camera preview works fine.
    From options dropdown choose GPS overlay
    Throws an error ->
    Retrieving the COM class factory for component with CLSID
    {8B4A194C-061F-4E53-BEE5-08B55129CB9D} failed due to
    the following error: 8007007e
    What did I do wrong?
    C
  6. #496
    Nov 2003
    Blonde moment... Tried to run before walking...
    Set the capture paths properly (I dont have a D: drive!)
    Then picked up the filter wossername from here-
    http://curioustech.home.insightbb.com/dsgpscode.html
    and now!
    Yay
    C
  7. #497
    Mar 2004
    Florence Yall, BFKY
    Well, now we know where on earth your chair is.
  8. #498
    Nov 2003
    Quote Originally Posted by Curiosity View Post
    It's our official Dr Evil chair
    C
  9. #499
  10. #500
    Dec 2005
    Perth, Australia
    Thanks for this, it now saves at 30fps
    I still get the error if I try and hit record again, screenshot it:
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 09:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 07:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 11:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 04:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 01:27 AM
