Page 57 of 102 FirstFirst ... 7474849505152535455565758596061626364656667 ... LastLast
Results 561 to 570 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #561
    May 2009
    Well did some messin around and seems to work great now... still wont work with Divx 6.8.5, hit record goes to black screen and saves a 0kb file then no preview anymore.. not to concerned though the hibernation is working great now (stops before hibernate, starts new recording on resume from hibernation).... still using Indeo 5.10 @ 640x480@ 30fps, its about a 1gb/Hr of record time, that I can live with, Im rotating 7 files...
    One request, any possiblity of adding a custom text box on the GPS overlay.. maybe a 10-16 character box to stamp on the video with the GPS info??
    Thanks again for the notepad trick... it works great!
  2. #562
    Dec 2005
    Perth, Australia
    Quote Originally Posted by maverick69can View Post
    One request, any possibility of adding a custom text box on the GPS overlay.. maybe a 10-16 character box to stamp on the video with the GPS info?
    +1
    Also for reference my sound is back in sync for no apparent reason (though I'm not complaining ) and I currently use CCCP (ffdshow) and I think currently WM7 or something, does about 300MB an hour? Might be 400/500MB actually.
  3. #563
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    There are a lot of codecs that don't work in real time and some that need adjusting. DivX and XviD are like that. Make sure you set it to 1-pass and try highest speed first (which usually looks terrible) and watch the CPU, then move up to higher quaility/bitrate. A lot of the formats in ffdshow seem to work, like H.264, MPEG-4 and WM7. I just keep forgetting to install it in the car.
    @f1ip: I fixed that FPS thing about a week ago. It was getting set to some random value when changing the res and would show blank on the config window. That could be your porblem. Make sure you get the latest.
    So should the custom text overlay be in a specific place or positionable? It does have the ability.
  4. #564
    Dec 2005
    Perth, Australia
    Quote Originally Posted by Curiosity View Post
    I would suggest the ability to just stick it in one of the drop down menu areas
  5. #565
    Mar 2004
    Florence Yall, BFKY
    Oh! Much easier than what I was thinking. Ok, it's done and uploaded.
  6. #566
    May 2009
    Excellent! Thank you!
    Im going to try some ffdshow codecs and see what happens.. I've tried the Divx set at 1-pass, max speed etc. etc. still to no avail..
    anybody embed this into CF yet?
  7. #567
    May 2009
    Heres a 20sec clip of it in action... hadn't downloaded the version w. custom text yet.. this was shot at 640x480@30fps using a CCD camera (need a higher mm lens) and USB capture card, using Indeo 5.10 w/ quick compress. Original 20 sec clips was 20.7mb so I recompressed with WMM down to 2.2mb, little bit grainier but not bad..
    Test2.wmv
  8. #568
    Dec 2005
    Perth, Australia
    Excuse me if I'm blind, but where did you hide the custom text option
    Also one more thing to add to your list, an option to start minimised?
  9. #569
    Mar 2004
    Florence Yall, BFKY
    The custom text is on the GPS overlay settings. Make sure you replace the old DSGPS.ax with the new one.
    So start minimised, start recording? Can do!
  10. #570
    Dec 2005
    Perth, Australia
    Replacing that file do I need to do a RegisterGpsFilter again or just simply have it in the same folder as GPSFilter?
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
