Page 6 of 100 FirstFirst 1234567891011121314151656 ... LastLast
Results 51 to 60 of 997
Thread: One-Click WebCam Recording!
  1. #51
    Jun 2005
    Norway
    Sorry, I didn't quite understand how to run multiple cameras, can you explain it a bit more simple?
    thanks
  2. #52
    Constant Bitrate Prefect's Avatar
    May 2005
    Switzerland
    @Go-carter: "multiple cameras" are not supported directly. Caputre! can only record from one camera at once.
    If you have two cameras (front and rear or so), you can copy the whole app to two different folders, say
    c:\program files\capture_front and
    c:\program files\capture_rear.
    configure the two config.inis to your cameras (in capture_front\config.ini set "VideoInputDevice=0" and in capture_rear\config.ini set "VideoInputDevice=1").
    Now you can make shortcuts to the two versions or add both in ces or cpos or whatever.
    Make sure that only one instance of Capture! runns at a time!
    I tried to access two cameras at once in another app, but the VIA C3 System was not fast enough for that...
  3. #53
    Jun 2005
    Norway
    I found it out, thanks
    I'm going to record both forward and the driver
    (sry for bad english...)
  4. #54
    Jun 2005
    i just downloaded the capture program and tested it on my laptop befor i put it on my carputer and all works well exept 2 things...
    when imbedded in centrafuse the preview screen streches the preview... rather than keeping the preview square (the actuall recording is fine)
    the second thing is when i hit start i get this...
    i lose my preview and get a blue section insted.... is this suposed to happen?
    thanks for any help...
  5. #55
    May 2005
    Switzerland
    Hi Tone!
    That's all correct, and not a bug but a feature!
    The "bluescreen" is the background image. You can put your own image there by replacing the "backround.bmp" with any bmp you want. (i have a picture of my car there)
    The reason for this is, that the VIA C3 System is not fast enough to record AND display a preview video.
    For the aspect ratio thing i could include a new config.ini value "WindowWidth" and "WindowHeight" so you can set your own window size if running in "WindowStateOnLoad = normal". Would that solve your Problem?
    My goal was to maximize the size of the preview window, regardless of the aspect ratio.
    Greetz! Chris
  6. #56
    Tainted Love Cris's Avatar
    Romania
    So this doesn't work on a Via?
  7. #57
    May 2005
    Switzerland
    Sure! The app is designed for a Via EPIA C3 System!
    Without the preview-window active while recording the C3 1GHz System is able to record at 320x240 with 30 fps and divx 5.2 compression and audio recording with mp3 compression while having CES playing mp3s and navigating with travelbook.
    It works very well, except that starting the app is a bit slow and after you pressed "start" the status display takes some seconds to show up, but recording is immediately.
  8. #58
    Romania
    I'm not sure it has anything to do with the program, but after I record something, and open the video file just captured, the file doesn't play. It says playing, but nothing on the screen...any ideeas?
  9. #59
    May 2005
    Switzerland
    @Cris: try deactivating the video codec and sound recording, change resolution and framerate, then try again. copy the video file to another computer and see if it plays there.
    what error message do you get when you doubleclick the recorded avi?
    Greetz, Chris
  10. #60
    Romania
    Quote Originally Posted by Prefect
    Greetz, Chris
    Thanks Chris. I've tryed all that, except copying the file to another computer.
    I don't get any error massage, just media player doesn't play the file. It says it's playing but the bar isn't moving. Sorry about the off topic, as I don't think it's related to your software. Could be my lousy camera...I'll test it in the car when the new cam arrives.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 09:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 07:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 11:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 04:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 01:27 AM
