Page 66 of 102 FirstFirst ... 16565758596061626364656667686970717273747576 ... LastLast
Results 651 to 660 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #651
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    There's a file in the zip with the filter named GPSOSD.cpp which has example code to access the shared memory object. There are 8 OSDItems that can be set with an X, Y position and text. They can be changed as often as you like.
  2. #652
    Dec 2005
    Perth, Australia
    Curiosity just one thing I noticed tonight, if you put Dir+Course by itself in either of the top 'slots' nothing is displayed. However if you fill something under/above it with another item it does display
    EDIT: Oh and I re-installed everything on a new laptop and no longer have the sound sync issues although it has crashed once so far but otherwise working better than my older laptop.
  3. #653
    Jan 2009
    Quote Originally Posted by Curiosity View Post
    i'm not that good in c
    does somedody have a running program that i could tweak to my application
    a least i would know it was working at the beginning
  4. #654
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by yorky View Post
    Oops, fixed it. Both far top and bottom were being ignored if the inner ones were disabled. Download again.
  5. #655
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by moreause View Post
    I'll help you convert it to VB. It should be pretty easy. Google found quite a few examples of shared memory...
    http://social.msdn.microsoft.com/For...6-00ba4cedf27c
    All we need are the delcarations to convert the functions, then redefine the structs and it should work.
  6. #656
    Sep 2009
    Question
    I'm trying to get the Xport and Minicam working.
    I have a NMEA GPS connected via a prolific usb -> serial adapter which Xport recognizes and the data is good if I connect to one of the virtual ports with hyper terminal Ican see the valid data.
    I've registered minicam and started it selected the camera and it will capture with no issues but there's no overlay of GPS data.
    I noticed Xport doesn't show any connections when minicam is running is there a setting I missed some where?
    I've tried one two separate computers on is an Imac with XP pro using the built in camera the other also XP pro using a fire wire video camera.
    Sean
  7. #657
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Maybe I can help,
    When the Minicam is displaying gps data okay, it won't show in xport, minicam somehow takes the info directly from xport. No COM port is used/needed from those xport generates.
    Do you get 2d or 3d fix with xport? The gps setting is ticked inside minicam (I think there is one, but maybe it's the capture ultimate I have in mind)? You should get the gps data...Have you try the data with another GPS application? I'd have no idea what NMEA data looks like, but I wouldn't think it would be obviously valid, but that's me, of course!
    One question, can you record with minicam? I get corrupted file names in the box, nothing gets recorded and I get an error message.
  8. #658
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by RipplingHurst View Post
    Sorry I've been so busy lately. The latest MiniCam dated 9/16/09 doesn't modify the filename string. Make sure you try that one. Give it a prefix like "F:\Video\File" and it will add the date, but not show it in the box. I think that should help.
    @ve6ar check your fix like RipplingHurst said. The overlay only shows valid information. The latest XPort shows GPS status on the bottom. As soon as that shows 3D, the video will start showing the text.
  9. #659
    Jan 2009
    the first time it took me almost .5 hour before i got any info on the screen
    and i don't know if there is something with xport...i become 3d and then sometime after a while i become 2d of even goes of
    and i try connecting garmin pc true xport and i was at 300 km from my location i never was able to hav a real fix after a hour
    connected garmin directly and was working perfectly after a couple of minutes
  10. #660
    Mar 2004
    Florence Yall, BFKY
    Have you tried XPort 1.38? There may be some changes that help. I've lost GMPC at the moment but I remember it worked a little odd. It reminds me of the old DOS programs that poll a 1 byte UART so it doesn't drop bytes. I'll try to find it and make sure it's 5.00.20 I think. The one that worked with GPSGate.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
