Page 67 of 102 FirstFirst ... 17575859606162636465666768697071727374757677 ... LastLast
Results 661 to 670 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #661
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Quote Originally Posted by Curiosity View Post
    Sorry I've been so busy lately. The latest MiniCam dated 9/16/09 doesn't modify the filename string. Make sure you try that one. Give it a prefix like "F:\Video\File" and it will add the date, but not show it in the box. I think that should help.
    Thanks, I'll try that!
  2. #662
    Dec 2007
    Danville, CA
    Well, I tried again the new version, the file name does not get corrupted, but nothing gets recorded. This is what I tested:
    - I tested first the same settings that work in standard capture! FFDshow encoder, same resolutions, bit rate, etc. Nothing happened in the folder where the file is supposed to go. I tested mp4/xvid, both work with capture, nothing gets recorded. I changed location (there was a space in the folder name, I chose a simpler one, nothing happened), I changed from drive F: to C:\videos\file.avi, not a difference.
    - I tested recording with and without preview. It's previewing alright (GPS info is all there, fine), the minute I click the REC button, the image goes away, and it does not come back. Nothing gets recorded.
    - I tested start recording button, after a restart. Everything loads, I click on the program icon. No file is created, and it starts with no picture. Even if I unclick preview in the settings, the pictures do not show. If I restart it, it will show, but no recording.
    - I unticked multifile recording, etc. all the options, still nothing happens. The counter on the lower right, is it supposed to start counting down when recording? It doesn't. I click on it, it changes settings okay, but it means nothing, no file is created. Some pages ago somebody did get it to work, but maybe something in my system is not working.
    At least I don't get any error messages, unlike capture ultimate! Capture! works fine, no gps, but I can wait...I'll keep looking here for a new version, thanks!
  3. #663
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Well, heck. Ok, if you want to do something for me I'd apreciate it. Get this one...
    http://curioustech.home.insightbb.co...niCamDebug.zip
    Then get this: http://technet.microsoft.com/en-us/s.../bb896647.aspx
    While DbgView is running, start up the new MiniCam. Any kind of error messages will show up on DbgView. Show me what that shows and I can at least narrow it down to what it is.
  4. #664
    Jan 2009
    Have you tried XPort 1.38? There may be some changes that help. I've lost GMPC at the moment but I remember it worked a little odd. It reminds me of the old DOS programs that poll a 1 byte UART so it doesn't drop bytes. I'll try to find it and make sure it's 5.00.20 I think. The one that worked with GPSGate.
    is there a 1.38 version ??
    when i go on the site it says 1.37
    i currently use 1.36
  5. #665
    Mar 2004
    Florence Yall, BFKY
    Oops! Yes, now that I updated the link.
    Been busy with OBD-II for the filter.
  6. #666
    Dec 2007
    Danville, CA
    You're not going to believe me. This new debug-modded-Minicam I downloaded worked!
    I can post the debug file if you want to, but no errors AFAIK.
    It started recording, with or without GPS data, everything worked fine. Files were being recorded, I tested them, they played fine.
    I thought, what the heck, does he have another updated minicam version on the site, I downloaded that, unzipped over my minicam directory, re register the relevant files, and no, that didn't work either. The log file on the regular minicam only records one line, with 5-7 random characters.
    I'm posting the zip file with the log made as per instructions above, that is, with debug minicam (successfully) running. What gives?
    Attached Files Attached Files
  7. #667
    Dec 2007
    Danville, CA
    What's new on xport 1.38? Does it check for a gps com port every x secs as did 1.37 I downloaded (to use with gpsgate) -- I'm concerned if I have a one-off version that I should lock in a safe somewhere...:-) ? Why does xport goes from the taskbar to the top most windows after resuming from hibernation? Thanks!
  8. #668
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by RipplingHurst View Post
    What gives?
    LOL. I believe you. While I was adding debug statements to the code, the compiler decided to show me a basic syntax error in a line of code that it missed many times. So I fixed it. That code has to do with the filename. Ok, I just uploaded that fix without debug. Strange that it's been working.
    What's new on xport 1.38? Does it check for a gps com port every x secs as did 1.37 I downloaded (to use with gpsgate) -- I'm concerned if I have a one-off version that I should lock in a safe somewhere...:-) ? !
    Yes, it still checks. It was throwing exceptions before so this one's safer. You can also connect all apps to the same COM port. I saw other splitters were doing that, so threw that in.
    XPort opens the control dialog when you run it while it's already running. There's no need to run it twice. Or once for that matter. It's executed by the OS.
  9. #669
    Dec 2007
    Danville, CA
    Heh, thanks for the updates. I'll download the xport version. Just copy over the current one?
    Is this the link?
    http://curioustech.home.insightbb.com/dsgpscode.html
    I just downloaded the minicam, and the files have the same dates on the zip file (latest mod 9/19). I tested, didn't work. How do we know which version is it?
    Thanks.
  10. #670
    Mar 2004
    Florence Yall, BFKY
    Yes. Just copy over the old ones. MiniCam.exe should be dated 9/27/09. Clean up your Tempory Internet Files. It might be cached.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
