Page 73 of 102 FirstFirst ... 23636465666768697071727374757677787980818283 ... LastLast
Results 721 to 730 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #721
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    800x600? Wait, what? OK, I haven't tested it yet. I think it needs an auto-color based on luminance. That looks a little dark on top and bottom.
    The fix was in an ASCII to unicode convesion function. MultiByteToWideChar(). The last parameter is the size of the destination buffer, which I set to size-1. Changing that to source length + 1 made the difference. It must be some kind of bug in microsoft's code. Oh well, good to see it's working!
  2. #722
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Just couple of (much) smaller issues:
    1. Any suggestion on the best Audio codec? 4kpbs is horrible, staticy and broken everywhere of course. But I can't seem to have much luck with others, they all seem to increase CPU utilization more than one would expect. I mean, 800x600@15fps is 20%, with audio on, pretty any encoder, it gets to 40-56% (depending on encoder). 960x720 about 24% (no audio), 56%-60% (with audio).
    2. The start minimized option actually sends it to the Windows 7 tray, and it's not obvious it's there. I started like 4 copies until I realized they were indeed being opened (the tray in the Win7 hides most icons under one). I actually like that behavior, but I thought you should know. Also, the overlayed minimize button does not send it to tray, however, but to the taskbar. There is no way to send the program to tray, unless restarting it.
    3. My camera supports 960x720@30 fps, as 800x600 @ 30fps, many others. However, the list on the settings menu only show ONE resolution "640x480 (30)" at @30fps, all the others has a (15) indicating 15fps -- and that's what's being recorded. The FPS setting even when set at @30 or @29.xxx fps does not change the file being recorded: it's still 15fps.
    4. Is there any way to tamper with the number's displayed? (say in the registry or text file). How difficult is it? Say to change the time or speed readings right before/as they are being recorded? Just because I was asked about it and didn't know for sure.
    5. Number of files = 0 means no limit, right? As in MB limit=0, means unlimited, correct?
    Thanks!
    RH
  3. #723
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by RipplingHurst View Post
    PCM should sound good. I always thought it was 16 bit, but could be 8 bit? There's always uncompressed.
    Start minimized isn't working for me on Win7. It doesn't seem to do anything, so I'll see what changed and try something different.
    The listing just shows what the camera reports as its capabilities. Those are stored in the driver. Minicam sets it to whatever you request though, so something else drops it back.
    Tampering is illegal. I actually made it difficult on purpose.
    Correct. Files, MB and time all use 0 as unlimited.
  4. #724
    Dec 2007
    Danville, CA
    Quote Originally Posted by Curiosity View Post
    I'll try that, thanks.
    It does start, but it's hidden with all the other icons under the tray icon thing. Check your process manager before and after. At least that's how it works here. I'll double check that.
    Hummm. I'll see what else I can do. Maybe I can modify the driver .inf settings then.
    As it should be! Thanks, good to hear that, that's what I'd expect to hear from my possible expert witness.
    Got it
    Any plans for an archieve button, like on the old Capture! ? It's useful on long trips, you don't have to search and move the interesting files. Right after an accident or funny incident you press a button, you know the relevant files will be safe somewhere and will never be erased later in the trip.
    Thanks.
  5. #725
    Dec 2007
    Danville, CA
    Now I realized that when you pause the video on WMP7 to take a screen shot, it darkens the top and bottom part of the screen. It looks fine in the car!
    Sorry I didn't catch this up earlier!
  6. #726
    Mar 2004
    Florence Yall, BFKY
    Well, it still might be a good feature to add an automatic text color.
    I don't think it would be admissable as evidence because it could easily be post-edited, but then it could be verified by calculating time over distance with the video and such.
    I never know what the archive was for! Now I understand. Mine just dumps all the video to the home PC when I drive up so I never thought about it. So it moves everything or just the last file?
  7. #727
    Oct 2007
    When you press the archive button you could save the current file, move it to a sub-folder and start recording a new one. So it would be pretty much to force using a new file and saving the previous one to a different folder.
  8. #728
    Dec 2007
    Danville, CA
    No, please, don't make it move everything. I have tons of files to sort through that all start with my garage wall, only some actually move away from it, not very interesting to look at!
    I do think it should be admissiable as evidence, but one that should corroborate other evidence (skid marks, impact on other cars, time over distance measurements, etc.). There is a difference between proof and evidence, and although a video is not definitive proof, it stil qualifies as (one among others) evidence. Better (I hope) than the testimony of some old hack on the street saying, "yeah, he was coming too fast - those soup'up cars always do; this was bound to happen" etc.
    The archive should save at least the last two files, because you never know if you're saving only about a second or two of the last file. I think Capture actually saved just one, if the last one was larger than 30 sec, or the last two, if it was <30 sec. It's important to be able t save it to a diferent directory (as Capture! did), usually it's an old USB card or directory that is automatically synchronized with your home computer. And then it should start recording a new file.
    Humm maybe it could be made to sync over the internet evertime the car is parked and it stays 15 min ing nothing, when the doors are locked or the IGN is cutoff. If the file is less than 250Mb it's doable over 15 min and 3G. But let's not digress.
    I also noticed today that it does not start minimized (you were right all along). I'll test later if it's because it's set to start recording and previewing.
  9. #729
    Mar 2004
    Florence Yall, BFKY
    You make a good point. Video of any kind wins over testimony of some stranger. Strange or not.
    I'll start on the archive feature soon.
  10. #730
    Oct 2007
    does miniCam constantly write to the file? I think RRCam would only write the file when hitting stop recording. If it crashed mid-recording nothing was actually written to the file. In case of a major system malfunction like in a vehicle crash it would suck to loose those last seconds of video footage before power went out.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
