I have not tried that yet.
I just now got it working with Microsoft video 1... sound and video record but i realy want xvid.
I'll try what you mentioned.
Was the upload within the last two days? I just downloaded it yesterday.
where's the low cpu option? found it..
Low CPU option does not seem to "stick". If i check it and close out, the next time i go back to check configuration, its not checked.
Same happens even if running as admin.
Same hapens even if running compatibility for xp sp3, and with admin.
---------edit-------
Unregistering the GPS filter i can now use XVID to record without the 0 byte file problem. But i really want xvid with gps info... hmm.
---------edit--------
I reregistered the filter to try again with xvid, and it seems to crash the app when i hit record.
Maybe this helps: ?
Problem signature:
Problem Event Name: APPCRASH
Application Name: MiniCam.exe
Application Version: 1.0.0.0
Application Timestamp: 4afaff71
Fault Module Name: xvidvfw.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4a2bcd84
Exception Code: c0000005
Exception Offset: 000098f4
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Specs:
Win7 x86
2gb
intel dual core
intel 4100 vid.
1Likes
LinkBack URL
About LinkBacks
