Page 80 of 102 FirstFirst ... 30707172737475767778798081828384858687888990 ... LastLast
Results 791 to 800 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #791
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    No. Capture stops on hibernate, then starts on resume with a new name. MiniCam does the same thing. We can't easily append to an existing avi, so a new file has to be created.
    Is this the error? "<device> is in use or cannot be rendered. (number)"
  2. #792
    Apr 2009
    Sorry to ressurect an old thread. I am getting the same issue with the 0kb files when the gps overlay has been registered.
    If I un registering the filter it works.
    This is using the lastest file from the website. Does the debug version in this thread resolve this problem?
    fyi this happens even with the xvid ffdshow pack.
    any ideas?
  3. #793
    Mar 2004
    Florence Yall, BFKY
    Oh, I didn't think about it being the GPS. From what I understood MiniCam had the problem. The debug version along with some output from DbgView on a system with the problem was supposed show what it was doing, but I never got any info. So the fix for now is unregister the GPS overlay. Sorry.
  4. #794
    Sep 2008
    Western Australia
    With the GPS filter registered, my USB capture card (EZCap) had the 0kb problem with Minicam, but worked fine in WinAVI / other programs. Tried different codecs/etc. At the same time, my normal USB webcam recorded fine.
    Now that I saw the above posts, I unregistered the GPS filter and now the USB capture card records fine.
    Although I haven't had time to run the debug yet, let me know if it would be of any use to yourself and I shall try it out.
  5. #795
    Mar 2004
    Florence Yall, BFKY
    OK, that makes a little more sense. It works with a webcam but not EZCap. The EZCap output pin may not be compatible with the GPS filter input pin, which is RGB only. It might only have a YUV or YUY2 output. That's the big difference between MiniCam and the rest. It connects all the filters manually so it doesn't stick conversion filters between them. I just need to add a conversion there if it fails.
    Oh wait... Do you see the GPS overlay when it's previewing, but stops when recording? I wouldn't think so.
  6. #796
    Mar 2004
    Florence Yall, BFKY
    Updated. I added a color space converter, but hard to test it here. Give me feedback.
  7. #797
    Apr 2009
    Cool. I will test the updated version.
    Do you want me to run the debug version if not and give you the output?
  8. #798
    Apr 2009
    Right, I just tested the latest version and I get the same problem.
    The thing is I am using a normal webcam and have always had this problem. I have tried 2 different ones and the problem is still there.
    once again the problem disspears when I unregister the filter...
    Thanks for your continued help!
  9. #799
    Mar 2004
    Florence Yall, BFKY
    Yes, debugging would help me a lot. Here's a new special one with lots of debug info. http://curioustech.home.insightbb.co...ms/MiniCam.zip
    And the output will go to DbgView
    http://technet.microsoft.com/en-us/s.../bb896647.aspx
  10. #800
    Apr 2009
    Ok np.
    I will run the debug version with debugger output and will post on here tomoz.
    Thanks again.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
