Page 81 of 102 FirstFirst ... 31717273747576777879808182838485868788899091 ... LastLast
Results 801 to 810 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #801
    Sep 2008
    Western Australia
    Okay so with Minicam before I updated it:
    GPSFilter off: EZCap records fine
    GPSFilter on: EZCap previews with the GPS overlay showing correctly, but doesn't record anything to file. Even when forcing a new file by stopping/starting recording or pressing the folder button.
    With the updated Minicam, does the exact same thing as above. Tried looking in the EZCap driver settings to see if it can be changed to RGB but couldn't find any option for that.
    Attached is a debug log file from when I was running the updated Minicam
    Attached Files Attached Files
  2. #802
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    OK, that makes a lot of sense now. Thanks for the debug log too. It's not a problem with the capture device since it works with preview. The log showed that it can't connect the GPS to the video compressor, so I moved the color space converter there. It should work. Go ahead and download and try it. It has to be the codec that can't handle it. Maybe an older one or something. Hopefully it's compatible now.
  3. #803
    Sep 2008
    Western Australia
    Good news, it's working now. Although I had to change from XVID codec to MV1. My computer shutdown due to low voltage so wasn't able to test further.
    Since I didn't try a different codec with the previous updated version, I'm not sure if it was the problem then too.
    Do you have any suggestions for codecs apart from Xvid (if I can't get it working)?
  4. #804
    Mar 2004
    Florence Yall, BFKY
    Oh everything should work now. I use FFDShow (go back a couple pages to #76). Select "ffdshow video encoder" as the video codec. It has XviD, DivX, H.264, MPEG-4 and all kinds of others.
  5. #805
    Apr 2009
    wow! that was quick!
    Ok. Where do I download the latest version from? Your website?
    Mar 2004
    Florence Yall, BFKY
    Yep. Same file.
  7. #807
    Apr 2009
    Same problem with the latest version of your file
    Unregisterd gps filter
    re-registerd gps filter
    tried again with ffdshow encoder set to Xvid in config and DIVX but same thing,
    Blank 0k file
  8. #808
    Apr 2009
    I just ran the debug version with dbg view.
    Output attached.
    the first run was with video prewview enabled
    the second with it disabled.
  9. #809
    Mar 2004
    Florence Yall, BFKY
    Thanks for the debug log. It's the same thing. The compressor codec won't connect to the GPS output even with a colorspace converter. I had a great idea to try it in GraphEdit but forgot it works on mine. LOL
    I forgot to dump the result codes, so uploaded another one. Last time I promise! If anyone wants to debug it one more time?
    It has to be a different version codec everyone has. I can't think of anything else it could be.
  10. #810
    Apr 2009
    No probs.
    Using the ffdshow codec, I belive this is the same one you are using?
    Do you want me to download from the website again and post the debug output? (a bit confused here )
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
