Page 90 of 102 FirstFirst ... 408081828384858687888990919293949596979899100 ... LastLast
Results 891 to 900 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #891
    Oct 2006
    Hey Curiosity,
    I tried DbgView, but i get nothing on the report, is there a setting i need to enable?
  2. #892
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by CabrioBob View Post
    I tried minicam for the first time, works well but I have one issue.
    I can't let minicam record a video with resolutions other than 320x240.
    Sorry about that. I was just working on resolutions last time and messed it up. The latest is now with the res fix.
  3. #893
    Newbie BazzaAlpine's Avatar
    May 2009
    Cambridge, UK
    MiniCam won't restart the cam after coming out of hibination. All I get is a white screen and I have to close MiniCam and restart it to get it running with the web cam again. Not using it with any GPS or the xport app. Any ideas?
  4. #894
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by Punky View Post
    Hey Curiosity,
    Notthing at all? It should have an error message for just about anything.
  5. #895
    May 2009
    Cambridge, UK
    Nope nothing. It opens up as if it is starting okay but the window stays white. Codex doesn't seem to make a difference (in case that is any help). I have it set up to start recording as soon as loads but I checked and it's definately not recording, also I'm pretty certain it did the same thing when it wasn't set to record but I can't be 100% on that.
    It could be something to do with the webcam I 'm using. It's a cheapo Tecknic autofocus thing. I'm thinking about getting something better than that anyway like a hd web cam but that will have to wait till end of next month.
  6. #896
    Mar 2004
    Florence Yall, BFKY
    Make sure you have "Multi-File Record" enabled. Without that enabled it won't do anything. I guess it's not intuitive, so I'll change that.
  7. #897
    Newbie CabrioBob's Avatar
    Jul 2008
    netherlands
    switched to the new version 1.04
    resolution bug is fixed, but new ones arrived, Scenarios :
    - "GPS-overlay" disabled, my GPS-mouse not connected to the PC
    Result : a good recording !
    - "GPS overlay" enabled, my GPS mouse not connected to the PC
    Result : when starting recording minicam disappears (unloads itself from windows)
    - "GPS overlay" disabled, my GPS mouse connected to the PC (no GPS fix)
    Result : minicam freezes when start recording (white minicam screen)
    - "GPS overlay" enabled, my GPS mouse connected to the PC (no GPS fix)
    At the moment I don't have the ability to test with a GPX fix (I'm inside a big building)
    Debugview reports are attached
  8. #898
    Mar 2004
    Florence Yall, BFKY
    Hmm, that's odd. All configurations are working for me. Since all that was changed was setting the resolution, it's possible that you can only record at 320x240. Try that and see of it works better. If so, try a different cam. Also the last log showed a different app using a COM port. Those aren't my debug messages, but it's probably not interfering with XPort.
  9. #899
    May 2009
    Cambridge, UK
    Quote Originally Posted by Curiosity View Post
    Thanks Curiosity, I'll give that a try. I thought that refered to have multiple instances of MiniCam running at the same time.
  10. #900
    Mar 2004
    Florence Yall, BFKY
    That makes it start recording again when the time limit hits, but I also used it to start when windows resumes. I think I did that as a test at one point and left it.
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
