OHHH!!! so that was my issue as well, i didn't have multi-file enabled either.
Will give that a shot tomorrow.
Printable View
How can I setup a button to archive in RR's main menu?
I don't know much about RR, but if it can send key commands try sending an 'A' to the window "CuriousTech - MiniCam 1"
I figured that it has something to do with sendkey, but I can't find an example to ape anywhere.
That's it, thanks a lot.
more problem for me :(
it appears that quickcam and/or webcam is causing sleep problem.
the software works perfectly, but then when i put the pc to sleep (windows 7 s3 sleep), when its suppose to resume, the computer restarts and win7 display "windows unshutdown improperly" caused by bluescreen. can i record any error using dbgviewer?
All you can do is make sure you have the latest Windows 7 certified drivers for that cam if that's the problem.
To debug a bluescreen crash, you'll need to set dumps to small and use Dumpchk to analyze it. http://support.microsoft.com/kb/315263 That's for XP but it's the same in 7 (6.1) Most of the information is useless but somewhere around the bottom is a "Possible cause" driver, which most likely the problem.
I've been trying to follow this thread but it is very long and I missed a lot of pages. I have a few questions which I think should be outlined in the first post. I keep checking back there but the original hasn't been updated since 2006.
1. What is minicam and how does it differ from Capture!?
2. What is this GPS overlay people are mentioning?
3. Will this work in Windows 7?
4. Are there new features added in the last year or so?
