Page 91 of 102 FirstFirst ... 4181828384858687888990919293949596979899100101 ... LastLast
Results 901 to 910 of 1016
Like Tree1Likes
Thread: One-Click WebCam Recording!
  1. #901
    Oct 2006
    OHHH!!! so that was my issue as well, i didn't have multi-file enabled either.
    Will give that a shot tomorrow.
  2. #902
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by RipplingHurst View Post
    Would love to see a button to start/stop previewing when recording, to save cpu cycles and still being able to check if the GPS info is being recorded (generally it isn't but that's a Garmin issue I have after resuming).
    Try the new one
  3. #903
    mkl
    mkl is offline
    Apr 2007
    How can I setup a button to archive in RR's main menu?
  4. #904
    Mar 2004
    Florence Yall, BFKY
    I don't know much about RR, but if it can send key commands try sending an 'A' to the window "CuriousTech - MiniCam 1"
  5. #905
    mkl
    mkl is offline
    Apr 2007
    I figured that it has something to do with sendkey, but I can't find an example to ape anywhere.
  6. #906
    Constant Bitrate almera's Avatar
    Aug 2004
    Quote Originally Posted by mkl View Post
    Code:
    B,91,138,83,90,"ACTIVATE;CuriousTech - MiniCam 1||SENDKEY;A",
  7. #907
    mkl
    mkl is offline
    Apr 2007
    That's it, thanks a lot.
  8. #908
    Oct 2006
    more problem for me
    it appears that quickcam and/or webcam is causing sleep problem.
    the software works perfectly, but then when i put the pc to sleep (windows 7 s3 sleep), when its suppose to resume, the computer restarts and win7 display "windows unshutdown improperly" caused by bluescreen. can i record any error using dbgviewer?
  9. #909
    Mar 2004
    Florence Yall, BFKY
    All you can do is make sure you have the latest Windows 7 certified drivers for that cam if that's the problem.
    To debug a bluescreen crash, you'll need to set dumps to small and use Dumpchk to analyze it. http://support.microsoft.com/kb/315263 That's for XP but it's the same in 7 (6.1) Most of the information is useless but somewhere around the bottom is a "Possible cause" driver, which most likely the problem.
  10. #910
    May 2006
    Calgary, Alberta
    I've been trying to follow this thread but it is very long and I missed a lot of pages. I have a few questions which I think should be outlined in the first post. I keep checking back there but the original hasn't been updated since 2006.
    1. What is minicam and how does it differ from Capture!?
    2. What is this GPS overlay people are mentioning?
    3. Will this work in Windows 7?
    4. Are there new features added in the last year or so?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. Recording (web)camera to carpc
    By DaKyy in forum General Hardware Discussion
    Last Post: 09-05-2005, 08:59 AM
  2. iGuidance Recording
    By Cheekz185 in forum GPS
    Last Post: 07-22-2005, 06:56 PM
  3. Routis click ok
    By johnnyutah36 in forum MediaCar
    Last Post: 08-25-2004, 10:22 PM
  4. T-Mobile Internet
    By cavramair in forum Wireless Communications
    Last Post: 07-24-2004, 03:53 AM
  5. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
