Well, I had this problem once it was caused from using Relative Path filename locatiosn in the RR config file for the SKIN. When I used absolute path, it works fine, like "C:\RR\...."
what would cause this problem?
when i load RR and then play music and go back to the main screen all the buttons are non functional . you can press them and they appear to be pressed but nothing happens .I have to ctrl alt del and end task to shut it down.
Mark
Website: http://www.greenpowerenthusiast.com/
Car'Puter Project
- Xenarc 700TSV
- MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
- 1x 256MB Corsair XMMS DDR400
- M2-ATX
- Belkin 802.11G W-Nic
- Garmin 15H GPS
- WinXP SP2 (NLited)
you have to update your flash, see here
High CPU Load, Buttons Fail to Respond, White box / square around logo's
yea thanks that was it . i need to update my flash
