Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: Suggestion for USB flash syncing to carputer
  1. #31
    Mar 2004
    Well, if you are talking about just copying and not "syncing" then things are even simpler.
    Here are you requirements from what I can gather:
    New files on USB should be copied to HD
    Modified files on USB should be copied to HD
    Files should not ever be copied from HD to USB because USB is too small
    If both the USB and HD contain the same version of a file, it should not be copied.
    The command line package that meets these requirements is:
    rsync
  2. #32
    Jan 2003
    Ruston, LA
    Went to wal-mart and picked up a 1gb pen drive. If I get any spare time I'll
    see what I can come up with.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #33
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    I actually pretty much came up with what I need. Totally forgot to update this thread!
    Wrote this little C script
    Code:
    #include <iostream>
    #include <fstream>
    #include <Windows.h>
    #include <stdio.h>
    #include <cstdlib>
    using namespace std;
    int main()
    	SYSTEMTIME st;
    	GetSystemTime(&st);
    	int test = system("sync.bat");
    	if( test == -1)
    	{   cout << "Cannot execute command"; exit(1); }
    	ofstream outputFile("sync.bat");
    	outputFile << "ROBOCOPY \"G:\\Music\\Full Albums\" J:\\Music /S /Z /MAXAGE:";
    	if(st.wHour < 7)
    		st.wDay -= 1;
    	outputFile << st.wYear;
    	if(st.wMonth < 10)
    		outputFile << 0;
    	outputFile << st.wMonth;
    	if(st.wDay < 10)
    		outputFile << 0;
    	outputFile << st.wDay;
    	outputFile << " /W:300";
    	outputFile.close();
    	return 0;
    It will first run the synchronization bat (have to create a default one first), then it will rewrite that same bat but with the date that the synchronization just occurred on so on the next synch it only gets files since that date
    Then on the carputer side I just have a batch script that will copy all files out of the music folder on the flash drive and into the music folder
  4. #34
    Jan 2003
    Ruston, LA
    Well now wtf am I going to do with this pen drive ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #35
    Mar 2003
    Rohnert Park, CA
    Put porn on it?
    I feel bad now
  6. #36
    Jan 2003
    Ruston, LA
    Nah, I always meant to get one. You just gave me an excuse.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. compact flash raid
    By B3AND1P in forum General Hardware Discussion
    Last Post: 03-13-2008, 07:23 PM
  2. Replies: 6
    Last Post: 03-20-2007, 10:16 PM
  3. Replies: 9
    Last Post: 08-07-2005, 11:27 AM
  4. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 05:34 PM
  5. New CarPuter Suggestion
    By belezeebub in forum General Hardware Discussion
    Last Post: 12-19-2003, 12:43 PM
