Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Hibernate/standby, resume, battery ac tool
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I made this tool this weekend, and I thought I would share it with some others on the board here.
    It is designed to be used like the Startup folder in windows, you just put shortcts to programs you want to run in it, except that it can also run links when the computer goes to battery, goes to AC power, before hibernate/suspend, after resume, and also startup and shutdown.
    I made a vb script a while ago that would disable my touchscreen before I went into hibernate, then re enable it coming back (that is the only way I could get it to survive without physically unplugging it).
    I also had a program run when I went to battery power (I use a laptop) to force hibernation at a specific time (some apps prevent my computer from going into hibernation).
    My VB script stopped working for some reason, and I decided to do it right this time.
    Anyway, check it out if you are interested http://www.exitzer0.com/
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    nice, very nice.
    good work. Will be watching how it goes.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    nice work!
    Raw Wave justintime's Avatar
    Apr 2005
    What happens if I run a very long script/process upon hibernation? For example, it my process takes 4 mins to complete, will it hibernate after completion?
    In general, I think after you initiate a hibernation (or shutdown etc), any process you kick off needs to complete after 30 seconds, otherwise the process will become 'Application not reponding'
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Apr 2005
    Just read the ReadMe, which addresses my question...
    * The Suspend folder is processed when you standby or hibernate. The time for this to occur is fairly quick, so make sure that anything in this folder will execute quickly, or it may still be running on resume
    I think I still prefer the Interceptor tool that FRODO has coded. (Search forums if you're interested)
    EDIT: FRODO coded it, sorry!!!!
    Quote Originally Posted by justintime
    2002 Honda CR-V
    Jul 2004
    Austin
    no problem, I made it for myself mainly
    I actually detect the battery status, then run commands (sync, etc) then when that is done, run hibernate
    hibernate just disables my touchscreen.
    you only get an app not responding on shutdown, not on hibernate (on hibernate it will just hibernate anyway).
    It should work for long scripts on shutdown, and I could do the same for suspend/hibernate, but it is a little screwy, and I dont need it personally
    |V1 Virtual Display|
    May 2005
    Vienna, VA
    How do you detect "when that is done"? Do you wait for the app to just close itself? What syncing app are you using?
    I'm very interested in this. Thanks.
    Jul 2004
    Austin
    i was using rsync, but i have just recently switched to unison, though i havent decided if it is better or not yet,
    I just have a single script that runs on battery that checks to make sure we are still on battery when it is done, and if so, hibernates
    |V1 Virtual Display|
    Mar 2005
    UK
    I have made my own software version simular to this
    Shutdown Controller Software
    Oct 2005
    Is there a place to still download this program?
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  2. car battery
    By Slurpee in forum General Hardware Discussion
    Last Post: 09-08-2007, 06:30 PM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  4. Laptop battery died
    By jol in forum General Hardware Discussion
    Last Post: 08-22-2003, 04:55 AM
  5. Replies: 6
    Last Post: 08-06-2001, 03:58 PM
