Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: LEDs and PC controller
  1. #11
    Low Bitrate widower's Avatar
    Jun 2005
    BTW: To calculate the resistor value:
    lpt datapins are usually 0-5V
    A = LED on Voltage
    I = LED on current
    resistorInOhms = (5-A)/I
    so if A=3Volts and I=15ma
    resistor = (5-3)/.015
    which is 133Ohms. You can always start with a larger resistor if you aren't sure of the led specs. Say 512ohms and then reduce it until the brightness looks good. Don't exceed the LED forward biased current.
  2. #12
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by widower
    So if you are using a 2wire tri-colour led, connect one data bit to a resistor, then the resistor to the led, then the other led pin to another data bit. If the first databit (D1) is 0V and D2 is 0V, the led is off. If D1 is high and D2 is low, the led is red, if D1 is low and D2 is high the led is green and if you constantly change the led from red to green, you will see yellow (depending on how fast you switch).
    I would recommend against powering the LED directly from the data pins. IIRC, the LPT data pins can source/sink somewhere on the order of 10ma; LEDs are usually rated around 20ma (constant), not to mention if more than one LED is desired for increased luminosity.
    Also, what you describe there is a bi-color LED (I guess you're counting the derivative yellow as a 3rd color?) Tri-color (RGB) LEDs, at least the one's I've seen, are all 4-pin common cathode.
  3. #13
    Sep 2005
    There will be a quite a bit of LEDs involved, Iím lighting my entire PC case + possible ground FX. I initially thought I could do it the way widower suggested but then I would not have enough power.
    This is my general idea of whatís going down.
    Parallel port(sends data) --> PWM(sets the on/off timing) --> transistor(giving LEDs enough power) --> resistor(setting the exact power required) --> LEDs(light up my soon to be drop dead sexy computer)
    Do that 3 times, one for each color.
    Is that about correct?
    Mushin, thank you SO much, I probably appreciate much more later (not that I don't now). You have been a great help.
  4. #14
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    above the last post.
    Not only that but you cant 'program' the lpt port to do pwm and just leave it running, no such commands exist.
    You can leave a pin high or low, but not pulsing.
    You would need to write a program to run in the background doing the pwm (at cost of cpu) and a program to set the levels for the background driver.
    hardware. Pic chip. job done.
  5. #15
    Aug 2004
    SE Michigan
    lez, I wasn't pushing him towards a PIC because that's another can of worms for a complete beginner.
    lez is right though, the software needs to be constantly refreshing the LEDs to maintain colors. Ultimately, it is more elegant to have a uC (or hell, a display controller IC) handle this duty, but I'm sure 2n193r can tackle that step if and when he feels ready.
  6. #16
    Jun 2005
    There are multiple circuits you could build that would help offload the PC. For simplicity sake, you may want to for LED pwm controller ICs. Maxim often have funky chips like this. You could then hook the chip to the parallel port in order to control it from the PC.
  7. #17
    Sep 2005
    PWM question, how would you change the duty cycle on a chip like this one?
    http://www.allelectronics.com/cgi-bi...M-2&type=store
    I thought that you would some how set the duty cycle and it would stay at that particular rate. (I could be miss understanding you guys)
    Quote Originally Posted by mushin
    First I want to build it the way with the PWM then I can do it with PIC(I just read a little bit about them but they sound cool).
    Well I will do that after I do this idea that is kind of pointless. Have the front door of my pc open automatically by some sort of sensor with 3 LEDs that are red that fade from dim to bright red. Then activate that sensor any have it close.
  8. #18
    FLAC -zip-'s Avatar
    Ontario/Canada
    wtf are you guys talking about? LOL
    *much respect for the engineer peeps on this board.
    Sound Stage
    Eclipse|MTX|Infinity
  9. #19
    Low Bitrate slantman's Avatar
    Apr 2005
    north augusta SC
    you may find something on this site
    http://store.qkits.com/category.cfm/PC
  10. #20
    Jun 2005
    Quote Originally Posted by 2n193r
    You're better to find a led pwm. The device you are pointing to is a current mode pwm. It's used for designing power supplies.
    Take a look at http://pdfserv.maxim-ic.com/en/ds/MAX6966-MAX6967.pdf
    It has a spi interface which is basically a synchronous serial interface so it should be easy to control from the parallel port.
  1. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 11:48 PM
  2. PC boot problems
    By Dave One in forum General Hardware Discussion
    Last Post: 07-17-2005, 06:24 PM
  3. Ultimate control over interior lighting
    By impulsenine in forum Hardware Development
    Last Post: 06-23-2005, 11:42 PM
  4. Remote PC Power Switch
    By Terran in forum General Hardware Discussion
    Last Post: 01-06-2005, 09:13 PM
  5. Custom Dash with car pc status leds
    By M^ck^y in forum General MP3Car Discussion
    Last Post: 09-08-2004, 01:03 PM
