Results 1 to 10 of 10
Thread: help with c++ - trying to execute a bat
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    I wrote a small C++ app that first runs a batch script then rewrites that same batch script to include a new date
    The date part is fine and works but the batch script refuses to run and I get no errors
    Source
    Code:
    #include <iostream>
    #include <fstream>
    #include <Windows.h>
    #include <stdio.h>
    #include <cstdlib>
    using namespace std;
    int main()
    	SYSTEMTIME st;
    	GetSystemTime(&st);
    	ofstream outputFile("sync.bat");
    	int test = system("sync.bat");
    	if( test == -1)
    	{   cout << "Cannot execute command"; exit(1); }
    	outputFile << "ROBOCOPY \"G:\\Music\\Full Albums\" J:\\Music /S /Z /MAXAGE:";
    	outputFile << st.wYear;
    	if(st.wMonth < 10)
    		outputFile << 0;
    	outputFile << st.wMonth;
    	if(st.wDay < 10)
    		outputFile << 0;
    	outputFile << st.wDay;
    	outputFile << " /W:300";
    	outputFile.close();
    	return 0;
    sync.bat
    Code:
    ROBOCOPY "G:\Music\Full Albums" J:\Music /S /Z /MAXAGE:20050910 /W:300
    What am i doing wrong here?
    Super Moderator xBrady's Avatar
    USA
    When you say refuses to run I assume you mean that the system command always returns -1 right? If so try moving the 'ofstream outputFile("sync.bat");' line some time after the system(... command. That may be opening the file for writing and not giving you access to write it.
    EDIT: On the last line I meant give you access to execute it not write it.
    Installed.
    -GPSSecure- - GPS Tracking
    Mar 2003
    Rohnert Park, CA
    Moved ofstrem below the system() and it worked
    Thanks!
    USA
    No problem
    Installed.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    quick edit, brady.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    USA
    Quote Originally Posted by Quattro
    quick edit, brady.
    I don't know what you're talking about
    Installed.
    Mar 2003
    Rohnert Park, CA
    Do you know how I would shift the time down from UTC to Pacific time? It says its the 13th right now and thats screwing things up
    Dec 2003
    New York
    Its a difference of 7 hours from UTC and pacific, so if you can compare your time with the UTC it would be easy. So if is still before 07:00 just subtract 1 from the day.
    Installed
    Mar 2003
    Rohnert Park, CA
    Doh! That was too easy, thanks
    Fiinished source if anyone cares
    Code:
    #include <iostream>
    #include <fstream>
    #include <stdio.h>
    #include <cstdlib>
    int main()
    	SYSTEMTIME st;
    	GetSystemTime(&st);
    	if( test == -1)
    	if(st.wHour < 7)
    		st.wDay -= 1;
    	if(st.wMonth < 10)
    		outputFile << 0;
    	if(st.wDay < 10)
    		outputFile << 0;
    	outputFile.close();
    	return 0;
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    GetSystemTime() will give you UTC
    GetLocalTime() will give you local or whatever yours is.
  1. making a BAT file?
    By djmickyg in forum Software & Software Development
    Last Post: 06-08-2005, 03:24 AM
  2. Bat Mobile Install
    By Batmanatthenewb in forum Show off your project
    Last Post: 05-25-2005, 08:35 AM
  3. Help with a bat file
    By GARB-E in forum Operating System Optimization
    Last Post: 02-03-2005, 02:57 PM
  4. Great working tank circuit with backup bat.
    By NightHunter in forum Power Supplies
    Last Post: 04-29-2004, 09:51 PM
  5. Can a bat file do this?
    By BLACKOUT in forum Software & Software Development
    Last Post: 02-22-2001, 04:21 PM
