Results 1 to 7 of 7
Thread: Resume time from hibernation with EPIA M/B's
    Newbie toxsickcity's Avatar
    Mar 2005
    Thailand
    hello carputa people
    I have a laptop that I use as a everyday PC..
    It's pretty speedy and the thing I love most of all is Resume from hibernation seriously takes only 3 seconds.. even with large apps open eg photoshop...
    But my Epia MII 1.2ghz in the car is slow as ****.. even a quicker HDD is the carputa 15-20seconds.. resume for carputa would be a godsend if it was 4 seconds like the laptop!
    anyone got any ideas of speeding up the epia.
    Specs,
    MII - 12000 / 256MBDDR266 / 80GB 7,200 3.5" onboard vga audigy 2zs
    Pentium M 1.73ghz / 512MBDDR533 / 60GB 4,200 2.5" onboard Radeon X700 & built in Sound.
    can anyone here who have same spec as my carputa post the resume from hibernation time for your system..
    Jan 2003
    Ruston, LA
    You can reduce the amount of ram.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Mar 2005
    Thailand
    I have tried using the msconfig ram limiter and tring all sort of configurations and the resume time is slow and around 10-12 seconds..
    even with just 128mb of useable of ram..
    I've also tried adding 512MB instead of 256.. same thing, slow when decompressing the hibernation file to ram..
    I am sure it's either the cpu being bad a decoding... etc or bios disk i/o speed.
    as windows as yet to load any drivers i am sure that it's to do with the quality of the chipset, I am sure the chipset Intel 925PM in my laptop.
    but if anyone knows of another way, let me know..
    And YES I have defrag, partitioned and many other thing have been tried to speedup the system..
    Constant Bitrate Power_nisse's Avatar
    May 2004
    Sweden
    i would check the Harddive and the connections of it!
    Make a speed test or some thing, DO you think the harddrive is fast when you have booted up? Its on the master jumper/cable.
    Try disconnect the audigy 2zs, i have never tried that card its a real CPU consumer!
    Ampie Case
    M1-ATX 90w
    EPIA ITX 1,3Ghz, Firewire
    80 GIG SATA
    512MB
    7 TFT Touch Super
    Pioner Slot in DVD-RW writer
    108 Mbit Wireless Lan
    100 M Bluetooth Range
    //Power Nisse
    My Betasite -> http://haagen.se
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    i have the same problem but mine is the 600mhz EPIA (MII 6000E) im using 256mb and it takes about 36 seconds or more to hibernate coming out of hibernation is around 20 secs but it takes so long even if i hibernate with nothing running at all.
    I would like 15sec altho i probably won't be able to with this board.
    Also im curious if you made the hibernation file read only could u in theory just turn the pc off then restart it up?
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    FLAC SFiorito's Avatar
    May 2004
    no, what you want to do is called Hibernate Once, Resume Many (HORM) which is a feature supported with the Enhanced Write Filter (EWF). Check the do a search for those two keywords for more info...
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Quote Originally Posted by toxsickcity
    10-12 seconds including the BIOS is not slow, that sounds about right
  1. Via Epia - can I use VGA and RCA video outs at same time?
    By nxt125 in forum General Hardware Discussion
    Last Post: 09-17-2005, 10:31 AM
  2. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  3. EPIA VIA M10000 Mini ITX in a 6x9 Speaker Box pic. 2 hour build time.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 02-13-2004, 01:24 PM
  4. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  5. EPIA M9000 & TM701 Problem
    By PTCruiser in forum LCD/Display
    Last Post: 03-28-2003, 02:43 PM
