Use obdii if you can - there are already cables and software to access many engine parameters from the ecu.
My boost readout from the ecu thru obdii is much more accurate than my mechanical boost gauge, so I don't know what you would gain trying to tap into the separate sensor voltages and use that to display onscreen.
Depends on the car for whether egt is supported or not.
LinkBack URL
About LinkBacks
