sweetness!!! Ill post a link for you on www.digital-car.co.uk too
thanks again![]()
All,
GATSO Hunter v1.0 is now available for download.
Instructions/information/link can be found on this page:
http://www.ignatu.plus.com/gatsohunter.htm
thanks again![]()
engram are the speed camera speeds changable because were i am we have speed cameras for te following speeds 60km/h 80km/h 100km/h 120km/h 140km/h 160km/h
and does your program give a warning for the which speed the is for??
thanks
I'm having trouble making sense of your post! But if you want warnings in km/h then you can do that.Originally Posted by vxr666
1. Make sure all the speeds in the CSV are in km/h. (Check my website to see what format the CSV should follow).
2. Next.. change this line in the config file: SPEEDUNIT=mph to SPEEDUNIT=kph. That will change the interface.
3. Finally, make new wav files for your km/h speeds. The wavs use the format limit_xx.wav where xx is the speed. You should be able to use 3 digit numerals there. So limit_120.wav should work.
Does that make sense?
I got the following error Mesage when trying to start the program:
"Type mismatch (Err no: 13 Source: loadSettings)".
This is caused bylocalization settings in Windows (my Windows install is using a comma "," as the decimal separator for instead of a ".".
In order to fix it, change the following in the .ini file:
WARNZONE=0.3
to
WARNZONE=0,3
very cool, i will be using this once i get gps setup.
One suggestion though, would it be possible to have it put a little red box at the corner of the screen or something when its not got gps signal?
So far - 1.1ghz athlon 4 Sharp Laptop, 256mb RAM, 20GB HDD, 32MB on board graphics. CDRW/DVD, 600W Boschmann amp, K301 InDash Screen
Interesting! I'll make a mental note of that one.Originally Posted by anohman
Ryan, the program can tell you about a lack of signal with an audio prompt and it's also shown in the status bar.
I'm not really open to new features at the moment. I just wanted to get it finished and available for people to use.
Did you get this working? i live in the netherlands and i am interested is this!!!Originally Posted by vxr666
And is it still possible to load the mapmonkey scv files? this becaus i live in the netherlands, and i have a very recent mapmonkey file, and dont know how to convert it...
www.superchargedmiata.net - all about roadster lifestyle
How do i make these wav files?![]()
yes it works perfectly but i didnt find any wav files with those speed limits.
you need to record your own
