Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 100% Plugin based Front End
  1. #11
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by frodobaggins
    I'm working on it as we speak.
    ETA: Year 2010.
  2. #12
    Low Bitrate Goofus's Avatar
    Feb 2005
    Durkadurkastan, FL
    Holy crap. For a minute there I thought I was actually smart and contributing to something here. What a relief.
  3. #13
    Oct 2005
    I’m writing a framework at the moment. Everything that sits in the framework is plug-in based and the framework will skin each plug-in independently.
    ETA: Around December to have the main framework and the sys-info/audio/video plugins working. When these are functioning correct and I shall release it and hope that people fancy’s writing plug-in’s!
    The apps rather imaginatively named MC^2 (Modular Car Media Control)
    I will most probably add the following plugins:
    Satnav,
    ODB,
    IO Control.
    Oh and somebody commented on efficiency. Well its not written in VB so that should help
    If anyone wants more info on it pm, post, email...whatever.
    Oh, its free (of course) and I will provide plugin example code.
  4. #14
    Feb 2005
    In theory then; each plugin would effectively act as separate app thats loaded when the button is pressed in the gui's main windo, so system resources would be dependant on how hungry the plugin at the time is being run?? Also, I guess load time would be minimal, as the main app would only need to read what plugins are in a folder and then display relevant buttons for them?
    As this is plugin based, would there be a generic button image with text overlayed be used, or is there another method?
  5. #15
    Constant Bitrate zzachattack2's Avatar
    Oct 2005
    Colorado
    Quote Originally Posted by custardbomb
    Kinda. Depending on the framework, the plugin may be loaded at application startup, only when its first called, or even every time it is called. The last one not being recommended, because most process need to perform background execution or retain its current state. That one would also hinder performance, having to create the plugin objects everytime it is called.
    Plugins are not seperate apps though (app be defined as a seperate system process). They are just objects(if object oriented) that are not hard coded into the main application, but reside in a seperate assembly which is then called and loaded from the main application (which doesn't know anything about the plugin, only that it usually inherits a common class or interface).
    As far as the button issue, I have seen this handled in several ways. One being how you just described, others being interacting with plugin to get an icon and text and generating a button that way, and another being pre-defined images built into a skin, which defines a set of required plugins. My framework uses a combination of the last two.
  6. #16
    Oct 2005
    For my framework:
    Plugins are loaded when its called, although I might have a little experiment to see the differing performance in loading them at startup.
    Mine are different objects.
    Pretty much except a little different in how that occurrs.
  7. #17
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Quote Originally Posted by polus
    Shouldn't it be (MC)^2 ?
  8. #18
    Oct 2005
    I suppose to be mathematically correct it should.
    Stop ****ing on my fire...
  9. #19
    Jul 2004
    All over the world
    lol, I'm just pulling your leg (and ****ing on your fire). I guess the order of operations is different in language than it is in math.
  10. #20
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    geeks....
    Roy
    2005 Range Rover 4.4
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 02-11-2011, 02:14 PM
  2. Web Based Front End
    By Zenith_Warrior in forum Software & Software Development
    Last Post: 07-02-2005, 07:03 PM
  3. Now a front end question?
    By nixneon in forum Newbie
    Last Post: 06-09-2005, 05:38 PM
  4. Front end needed for semi commercial venture
    By Orange Bus in forum Software & Software Development
    Last Post: 04-28-2005, 02:59 AM
  5. help:winamp hotkeys in Medicar and other winamp based Front ends?(concerning IRinput)
    By powerslide in forum Software & Software Development
    Last Post: 04-05-2005, 05:12 AM
