Results 1 to 10 of 13
Thread: HELP! I lost the control panel with tweak UI
    Maximum Bitrate clean customs's Avatar
    Jan 2005
    Houston
    I used tweakUI, and made it so the control panel doesn't show up in the start menu. Now I can't freakin open to change anything. Does anyone know how to get it back, or where else I can find the control panel?
    Any help would be appreciated alot!
    Kenny
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    um, goto start run, type control
    PC Components:
    My work log
    Dec 2004
    Maryland
    if run is gone....make sure my computer is on the desktop...if its not right click goto desktop, goto customize desktop, check my computer. Once in my computer.....control panel should be an option in there, if its not try changing view options until it shows (dont remember the exact setting for that)
    PC Components:
    My work log
    Jan 2005
    Houston
    Aww yea, thats it. Thanks man, you saved me some stress
    Jan 2005
    Houston
    That would have worked, but when I try to open it, its the operation has been cancelled due to restrictions. Contact your administrator. The program tweakUI was set I guess to not let me access things, but never told me how to get back there. Its almost like a catch 22, strange.
    K
    Jan 2005
    Houston
    Does anyone know how to change the registry back so control panel will show up? I can get to the registry from windows/system32, but I can't do a damn thing else. I have tried to remove framework, remove tweakUI, but I can't change anything that it did. Ive tried safemode, but I still get the same message that I can't access it. Some please help me before the comptuer gets hurt.
    thanks for any help
    Kenny
    Dec 2004
    Maryland
    start, accessories, system, system restore, go back to a registry restore point. I'm sure there are other regedit hacks out there for re-enabling the control panel
    PC Components:
    My work log
    Dec 2004
    Maryland
    PC Components:
    My work log
    Jan 2005
    Houston
    I didn't even think about a restore point. I might have to add a few things, but this is killing me.
    thanks man,
    Kenny
    Jan 2005
    Houston
    Got it, at least I happened to have a good restore point.
    thanks man,
    Kenny
  1. FS: USED 7" VGA TFT LCD panel w/ controller & inverter - $120!!!
    By NoPistonPC in forum Classified Archive
    Last Post: 05-19-2004, 08:49 PM
  2. Ceiling mount control panel
    By deadweasel in forum General Hardware Discussion
    Last Post: 12-02-2003, 02:10 PM
  3. Replies: 14
    Last Post: 02-26-2002, 08:42 AM
  4. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
  5. LCD + control panel almost done
    By RWAudio in forum General Hardware Discussion
    Last Post: 05-24-2001, 05:43 AM
