Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Enhanced Volume Control
  1. #11
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    I looked at the source code and that appears to be correct. The class module used doesnt support spdif. I searched for one that does and came up with nothing. There must be something out there though. I'll keep looking.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  2. #12
    Oct 2004
    There seems to be a prog called volumetracker.exe that might help but all the links to its download are no longer working. Can anyone find this program so we can see if it will work?
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  3. #13
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Let me see if I can come up with another method to control the windows Spdif input.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  4. #14
    Oct 2005
    Hou. TX
    Quote Originally Posted by GreenBeast
    so does this work 'through' another program like a front end?
    so when i press the volume buttons on Mobile Impact it can exponentially raise and lower the volume?
    It works at the Windows level. It works on my home PC as I'm not using SPDIF. If you open the volume panel in Windows you will see that the Wave and Master are now linked. When one is raised the other will raise as well. So when you raise or lower the volume in RoadRunner or whatever, Master and Wave move together giving you more volume range as well as speed.
    It's not really exponential either, it's just double the range and speed. There are some other options to increase the speed when the button is held, but I don't use them. Maybe that can make it seem exponential?
  5. #15
    Jun 2005
    Kent, England
    thankyou!
  6. #16
    Mar 2004
    New Jersey
    Quote Originally Posted by n8scstm View Post
    I know this is old but i still need a good spdif matcher this works but you manually have to set it. Can someone rip this apart? This matches the volume reaqlly smoothly.
    You can also run more than one instance of this so it works but again you have to re set it every time you start it.
    Attached Files Attached Files
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
  1. XM Volume Control
    By Kamakazie2 in forum Media Engine
    Last Post: 07-03-2005, 12:12 PM
  2. Volume control in Xenarc 700TSV
    By BMW-7 in forum LCD/Display
    Last Post: 04-07-2005, 12:08 AM
  3. Volume Control Solution, a good one too
    By clean customs in forum Input Devices
    Last Post: 01-26-2005, 10:40 PM
  4. Volume control buttons in external app mode
    By Bobby Digital in forum Media Engine
    Last Post: 07-30-2004, 01:24 PM
  5. hardware volume control
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 04-20-2001, 11:43 AM
